toshiba 42tl515u problems
  • nomoresonys
    • 12276
    • U.S.
    Re: toshiba 42tl515u problems
    Maybe you can test some components on the mainboard, might just be a 2 dollar part needed?
    • nomoresonys
      • 12276
      • U.S.
      A few repair services on ebay, they want about 100 bucks.
      • doesntmind
        • Feb 2014
        • 65
        • usa
        A few repair services on ebay, they want about 100 bucks, seems pricey.
        Thank you so much for your help! Do you know where I might be able to find a service manual on this so I can get a better idea on fixing the mainboard?
        • nomoresonys
          • 12276
          • U.S.
          I believe the member here named nickstvs does repair service, not sure tho, you would have to check with him, if you want.
          • nomoresonys
            • 12276
            • U.S.
            Some use this site. https://elektrotanya.com/
            • doesntmind
              • Feb 2014
              • 65
              • usa
              #26
              Thank you for this resource, I wasnt able to find my boards manual but I will keep this in bookmarks.
              So far I have been able to trace the BL_ONOFF to the collector pin of LY Q1001 on back side of board. Do you think I should attempt applying heat on the board for a bit in case it just needs reflow? any tips or suggestions?
              • nomoresonys
                • 12276
                • U.S.
                #27
                Hmmm, there looks like a lot of tiny components on the back, myself I would be worried I would lose some of them by applying too much heat, you might be right tho, not sure? there may be a way to test the components first without adding heat, to see if they are in working order.
                • nomoresonys
                  • 12276
                  • U.S.
                  #28
                  Might be a test procedure for LY Q1001.
                  • nomoresonys
                    • 12276
                    • U.S.
                    #29
                    It's a transistor, you can check youtube for transistor testing, some videos are better than others of course.
                    • R_J
                      • Jun 2012
                      • 9588
                      The transistor marked LY is a 2SC2712-Y, easy to check with a meter on diode test
                        Report the Voltages of all 3 pins with ref to gnd when TV is OFF and when power switch is activated.
                        Bur at this point you have more than just he BL-ON. Do you have PWM Dimming control signal?
                        Do you have 12VDC feeding the T-CON?
                        • doesntmind
                          • Feb 2014
                          • 65
                          • usa
                          #32
                          I have 164mV at PWM pin
                          the emitter pin on both transisters are connected.
                          the base of q1001 goes to a 10k resistor then collector of q1002.
                          the base of q1002 goes to a 4.7k resistor then to both emitter pins.
                          Q1001
                          pin - desc - standby - reading
                          1 - base - 0 - 700mV
                          2 - emitter - 0 - 5mV
                          3 - collector - 0 - 24mV
                          Q1002
                          1 - base - 0 - 6.2mv
                          2 - emitter - 0 - 6.2mv
                          3 - collector - 0 - 3.2V
                          • doesntmind
                            • Feb 2014
                            • 65
                            • usa
                            #33
                            forgot last question, i only found 3v on one pin but couldnt find 12v anywhere on tcon
                              Did you check right at both ends of the SMD fuse on the T-CON board? You know where the fuse is, right?
                              • doesntmind
                                • Feb 2014
                                • 65
                                • usa
                                #35
                                I read 300mV at both sides of fuse while system is on, 20mV when standby
                                  You have more than just no bl-on problem, the MAIN is not sending the signal to turn on the switched MOSFET to supply the 12V to the T-CON either.
                                  So more in-depth troubleshooting of the main board will be required, so you can spend lots of time locating the schematic of your main board and do more testing.
                                    09-06-2024, 05:27 AM
                                    09-06-2024, 05:59 AM
                                    Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                    This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                    09-06-2024, 05:33 AM
