LG 60pb5600 plasma random reboot
  • olivier.gendron@gmail.com
    • Aug 2018
    • 18
    Hey guys,
    I'm trying to fix my plasma T.V.
    Well, at first I had bad caps on both of buffers, now I have image but the tv "click" and reboot randomly every 5-10 minutes.
    Any help will be gladly appreciate;
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 60pb5600 plasma random reboot
    Look for cold solder joints on the PSU and Main Bd. You did replace the caps with the correct ratings and soldered them in correctly, right??
      • Aug 2018
      • 18
      Well, there was no info about the caps for the buffer over the web , at first it was a black screen problem. Then, I replace all commonly broken caps by something equivalent but 3kv instead of 1kv. I dont think its the problem cause it show the image perfectly now just randomly on and off. I'll check for cold solder joints on the PSU and mainboard. Thks
        • Aug 2018
        • 18
        Alright Guy its fixed now ! It was the main board and 2 500v capacitors on the sustain board, I had to replace the P. Sup for no reason but anyways Thanks for everything.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Thanks for the feedback. Good job!!
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
          • TRANSLTR
            LG 39LN5758 random reboot / off-on while watching
            by TRANSLTR
            Hey guys,
            a while ago my LG 39LN5758 started performing random reboots while I was watching something.
            It started during phases when the volume was set to higher level / the movie had a very loud sequence. The TV would suddenly go off and then reboot.
            After this event, it returned to nominal functionaltiy.
            But now - a few months later - sometimes the TV sometimes is in a loop, performing dozens of reboots before eventually reaching a somewhat stable operation.
            The error pattern let me thinking about a bad cap or some other issue with the Power...
            05-10-2021, 01:19 PM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
          • Vspeed
            LCD 31MU97Z displays random lines randomly
            by Vspeed
            I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
            I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ºC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V....
            01-22-2023, 02:26 PM
