Samsung PN42C450 B1DXZA Doesn't Power On
  • Eaglecrest
    • Jul 2018
    • 147
    Re: Samsung PN42C450 B1DXZA Doesn't Power On
    What is the best way to test out a new part before installing to make sure it is good?
    • Eaglecrest
      • Jul 2018
      • 147
      I disconnected the Y sustain (Y main) and Z sustain (X main) from the logic board and tested Vs resistance on the power board, Y board and Z sustain. The power board and Y board showed in the range of 30K ohms and the Z showed 0 ohms.
      I didn't try hooking up light bulbs, but did power on the TV with the boards still disconnected and the chime came on and VS shows 207 VDC, Va shows 53.6 VDC. I didn't check every other connector, but i was getting 15 VDC on CN801 and the 5.3V was showing 5.17V.
      This seems to indicate that the power board is good and that the issue is with Z sustain and to start by replacing the two FETs. Is this a correct understanding?
      Is it necessary or prudent to check all connector reading?
      I am assuming I can reconnect the Y sustain cable, what result would I expect to see once I do?
      • R_J
        • Jun 2012
        • 9535
        You have confirmed the fault is on the Z-sus, and the power supply is working, With the power disconnected, check the VS voltage on the power supply and wait for it to drop near 0 before reconnecting it to the Y-sus
        • Eaglecrest
          • Jul 2018
          • 147
          Is Renesas considered a quality part?
          Also I would appreciate some assistance understanding part identification. As i mentioned both transistors are marked:
          G
          RJH30E2
          071B
          I am assuming the part is RJH30E2, what do the other markings mean? Also when I google RJH30E2 I get some listings for RJH30xxx, how can I know if these are the same?
          • R_J
            • Jun 2012
            • 9535
            Yes Renesas is a good brand, if that is what you are actually getting, the last letters are date code so they will be different
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              #26
              Great!! So you have determined the Z-sus Bd as the faulty culprit. Can you get another working board? I would just go ahead and change the board, but if you want to give the repair a shot we are here to help you. Do as RJ says to let the Vs go down to 0Volts before reconnecting the Y-sus to prevent destroying the board.
              • Eaglecrest
                • Jul 2018
                • 147
                Is there any way to identify the manufacturer like many ICs have a logo? What does the G mean? I was assuming the last four were a lot code or something like that so date makes sense. How can i decipher it? I am assuming 07 is year if so what do the rest mean.
                Also I need to better understand the part nomenclature. If i look up "RJH30E2 datasheet" on google I get a variety of information that is not exact, e.g., https://www.alldatasheet.com/view_da...chword=RJH30E2 shows two parts RJH30H1DPP-M0 and RJH30H2DPK-M0. The first one seems more similar to what is in the TV, but I don't know how to be sure if it is correct or even a substitute?
                • R_J
                  • Jun 2012
                  • 9535
                  The original part is obsolete, and my have been a custom number for Samsung.
                  One of these things is not like the other, one of these things is kind of the same...
                  The two parts electronic specs are the same, the package and mounting are different
                  The first is TO-220FL (fully isolated case), the other one is TO-3 (exposed metal flange connected to collector)
                  Contact Renesas https://en.na4.teamsupport.com/dashboard
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    #29
                    [QUOTE=R_J;850106]
                    Sounds like Sesame Street
                    • R_J
                      • Jun 2012
                      • 9535
                      Sorry 'bout that
                      • Eaglecrest
                        • Jul 2018
                        • 147
                        I waited until the Vs reading was 0 before reconnecting the cables and then waited overnight before turning on the set. I plugged it in and got a click, then hit the power button and got the chime, but i noticed smoke rising up on the left side of the TV back (cover off). I didn't see where it came from, but the stream was long and came from near the bottom of the Y board on the left side which is where the FETs are located. I turned the TV off and unplugged. I waited for Vs to go to 0 and checked the Vs on the power board and the y board and there was no short.
                        Is it possible it was just some dust or hair that got smoked when power was turned on? The board is a little dusty and with dogs, hair is everywhere.
                        • Eaglecrest
                          • Jul 2018
                          • 147
                          Let me add that I never touched the Y board, except to take a voltage reading and that everything was connected, except the X main board.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            #33
                            OK. So disconnect the X-Main and see if Vs remains steady. If it does then we might be OK. Get another Z-Main Bd.
                            • Eaglecrest
                              • Jul 2018
                              • 147
                              Andrew,
                              You had mentioned that there wasn't a connection between the X and Y boards as far as shared failure. So I had reconnected all the cables except the ones to the X main, it was completely isolated.
                              I then plugged the TV in and then turned it on when I noticed a wisp of smoke (like after you blow out a candle). I immediately turned off the TV then unplugged and wrote in. Like I said, I wasn't doing anything with the Y board so nothing I have been doing should have caused a problem. Also not sure if turning it off was important as I assume that if something happened it happened and turning if off won't change that, but i felt it was the safer play.
                              So are you suggesting I should just turn it back on and check things out or is there a different play I should try first?
                              • Eaglecrest
                                • Jul 2018
                                • 147
                                Is there a reason not to try turning it on again or should I try to check something out first?
                                • Eaglecrest
                                  • Jul 2018
                                  • 147
                                  The transistors are on order. I was looking further at the Y sustain. There are three resistors that are the same value, 200K ohm-- R5036, R5041 and R5042. 5041 and 5042 read the same, but 5036 reads double.
                                  Can these be read in circuit or do the have to be removed from the circuit?
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    If the resistor reads double (400K) it could be bad or something could be throwing the reading off, Too be 100% sure you would need to remove it
                                    Try reversing the meter leads and check it again, if it still reads high it could be close to open.
                                    sometimes if there is a small voltage on the resistor (from a cap elswhere in the circuit) it can cause the meter to read wrong
                                    • Eaglecrest
                                      • Jul 2018
                                      • 147
                                      RJ, they are 200K ohms one reads 200K the other two 100K, in both directions. I am reading these off the legs next to the body of the resistor and was assuming that I would be getting the reading through the resistor. As I was thinking about this and I guess if the circuit has a lower resistance than the resistor then I guess I would get the reading through the circuit rather than the resistor. Is this a reasonable thought?
                                      • Eaglecrest
                                        • Jul 2018
                                        • 147
                                        While waiting for the parts to come in I looked at the TV again related to the Y Sustain smoking. With it attached there is no Vs voltage, but there was before. I removed all connectors and there was nothing. I attached the logic board and still nothing. I then added the main board back in and the TV powers up -- standby light on, start up chime. Series light bulbs light brightly for a couple seconds then turn off. Hit power on button and the bulbs light up (Vs=207 VDC) and then goes off. Previously without the Y Sustain connected Vs would show 207 VDC and stay on. Now it does not stay on.
                                        Press the power button and the bulbs light for a couple seconds then the standby light blinks 5 time and goes out. The green LED on the logic board blinks slowly. Press power button again and the TV turns off and standby light comes on again.
                                        What is this telling me?
                                        • Andrew F. Ali
                                          • Jan 2014
                                          • 2450
                                          • Trinidad & Tobago
                                          #40
                                          PSU damage.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
