Samsung UN40H5203AFXZA submitted for your disapproval.....
  • ga70gto
    • Oct 2014
    • 61
    Picked up this tv because the owner described it as "dead". It is in fact not dead, it has backlights and sound when connected to a DVD player, problem is "no display". if you leave both t-con ribbon cables connected and turn the tv on there is no image.
    Picture one is if you power up the tv with the left (as viewed from the front) tcon cable disconnected.
    Picture two is if you connect the left t-con cable while the tv is on.
    Picture three is once again with the left cable disconnected but you can see different results after cleaning the ribbon cables.
    Picture four is once again connecting the left t-con cable while the tv is on. I added it just because the display is different than the first test.
    if you think it necessary I can provide pictures of the boards but didn't want to waste the space on the website if most people think it's a bad panel.
    as always, thanks for your time.
  • R_J
    • 9623
    Re: Samsung UN40H5203AFXZA submitted for your disapproval.....
    On pictures 1 & 3 I see a dark shadow near the bottom, I wonder if this tv had its screen washed and water/cleaning fluid may have corroded the panel's board, the board that the t-con cables connect to in the panel.
    • ga70gto
      • Oct 2014
      • 61
      RJ, yes now that i'm viewing these pics without the "glow" of the tv directly in front of me I see those "shadow" areas too. I had the panel out to inspect for any physical damage such as the tabs pulled off and saw none. I didn't really see any staining at the base of the panel either but I realize if this panel has been fluid damaged there's probably no help for it.
      pete
        09-07-2024, 05:50 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • shelby5041
        Samsung LCD TV no picture backlight on no 12v at tcon
        by shelby5041
        hi
        i have a samsung lcd tv
        it powers on with sound and backlight but no picture
        all voltages from PS are good 12v 3.3v and 5v
        whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
        i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
        no 12v at the tcon fuse
        i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
        the odds of having 2...
        10-08-2021, 08:21 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
