LG 65UB9200 no image or sound
  • Jtroutt19
    • Aug 2011
    • 164
    You can hear the initial click from the power supply when you hit the power button but there is no image no backlight and no sound.
    Less than 1v per led pin at the connector for the backlight.
    When the unit is on voltage at the main board connector is good. There is a small red led on the power supply board towards the backlight connector. It flashes 5 times and then pauses for about 7 seconds before flashing again.
    Is the P/S bad?
    Re: LG 65UB9200 no image or sound
    The connector on the power supply board that goes to the main board has pin name for each pin, we need top know what the Voltage are when the TV off and when the power switch is activated, you must put down the pin name and follow by the Voltage reading when TV is OFF and when power switch is activated so we can easily see what are missing.
    • Jtroutt19
      • Aug 2011
      • 164
      Ok I remember being told that before now. Sorry. I will get that info first thing tomorrow.
      • Jtroutt19
        • Aug 2011
        • 164
        ok here are Voltage for the main connector. First column is power off second column is power on.
        Code:
        Column 1 OFF:ON    Column 2 OFF:ON
        SIN-    0v:0v     V-SYNC- 0v:0v
        SCLK-   0v:0v      GND
        GND            GND
        24v-    0v:24.8v    24v-    0v:24.8v
        GND            24v-    0v:24.8v
        12v-    0v:11.78v   GND
        12v-    0v:11.78v   12v-    0v:11.78v
        GND            GND
        3.5v-   3.5v:3.5v   3.5v-   3.5v:3.5v
        3.5v -   3.5v:3.5v   GND
        P-DIM-  0v:3.38v    P-DIM2- 0v:3.38v
        PWR-ON- 0v:3.43v      DRV-ON- 0v:78.2mV
        Last edited by Jtroutt19; 08-07-2018, 10:46 AM. Reason: trying to format for readability
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Looks like the DRV_ON voltage from the mainboard is missing.
          If you disconnect the mainboard from the power supply do the backlights come on?
          • Jtroutt19
            • Aug 2011
            • 164
            No I hear a click from the power supply like it is turning off. Then nothing
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              With the mainboard disconnected can you jumper the 3.5V to PWR_ON using a 1K resistor and a second 1K resistor between 3.5V and DRV_ON. The Backlights should come on.
              • Jtroutt19
                • Aug 2011
                • 164
                Yes back light does come on. I do not see any dim spot or anything. Looks great.
                This mean I am looking at a bad main board correct?
                Or would it be possible to repair the main board? What causes this particular issue?
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Lead free solder and corporate GREED cause this problem.
                  • Tomylee
                    No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                    by Tomylee
                    Sorry for the person who’s going to read all this !
                    I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                    While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                    During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                    07-11-2025, 11:52 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • jbsers
                    No image on QLED Samsung TV QE55Q85RAT
                    by jbsers
                    Hello everyone
                    I have a QE55Q85RAT TV that no longer turns on - to be more precise, here are the diagnostic elements:
                    - when I turn it on, the red LED flashes once, we hear a slight "zz" twice on the motherboard, then the LED flashes twice and this cycle repeats indefinitely and no image
                    - taking inspiration from certain forums, I put tape on 4 tracks of the ribbon which goes from the motherboard to the panel and then, the TV still does not show any image but the sound works and the TV responds to the remote control (I turned on the voice guide)...
                    02-08-2024, 08:37 AM
