Hitachi LE55A6R powers on but no picture/backlight
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    this is a FYI post
    i found a hitachi le55a6r in trash
    plugged in and has red standy light...powered it on and blue power light comes on but no picture
    flashlight test shows image there..so since this is a LCD LED tv i immediatley assumed it was a bad led light since this is very common in these tvs
    took tv apart....removed lcd panel...found 1 dark colored led ..removed plastic led lens and ripped led light off the board to expose the pads...jumper soldered the 2 pads together as 1 and now tv works great
    Re: Hitachi LE55A6R powers on but no picture/backlight
    Make sure to turn down the backlights level to as low as possible, also when you bypass the LED the PWM controlled MOSFET that maintain the constant current through the LED string will run hotter.
    • shelby5041
      • Feb 2009
      • 1504
      ok thank you
      bypassing 1 led makes that much of a difference?
      the tv has i think about 70-80 leds
        Each LED is about 1 Watts, so for the active device to maintain constant current, the Vdrops on the active device will increase when LED is bypassed, thus more power dissipation on the MOSFET.
        • shelby5041
          • Feb 2009
          • 1504
          thank you good to know
          but the life span on these tvs are so short 1-3 yrs that nothing much really matters anymore lol
          im sure the tv will fail in another way before that bypassed led would cause a failure lol
          • shelby5041
            • Feb 2009
            • 1504
            i got the tv for free so getting it to work period is most important...anything else im not worried about.....im just letting people know that this may be a common issue on this model tv so they can get their tv working again for no cost ....i could have repalced the LEd but i dont have one on hand and removing the led strip which is glued down could not go well so this was an easy way to get tv back up again with less risk of destroying tv even more..removing the led panel was not easy...i was very careful and it went well...
            • shelby5041
              • Feb 2009
              • 1504
              and these tvs are not worth putting more than $20 in them..since its only worth maybe $50 in working condition....the LED strips are too costly and not worth replacing...repalcing led itself is cheap but like i said i didnt have any..i ordered some last week for a diff tv but takes 30-50 days from china..
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                I ordered a supposedly β€˜new' Tcon board this time, and
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • afex
                Vizio E371VL Powers on, no backlight or picture, will not power off
                by afex
                hello, I have a Vizio E371VL - the orange Vizio logo lights up while not powered on, changes to bright white when power button pressed but there is no picture.
                There is no backlight, and I've done the flashlight test and cannot see any picture. The TV also will not power off using the button or the remote - I have to unplug the power cable to shut it down. The white light never fades out until unplugged. Its almost like its stuck in the powering up phase or something.
                I bought a replacement mainboard and replacement power board. Neither have fixed the issue. It still...
                11-08-2021, 09:20 PM
