Vestel 17mb82-2 dump for LTA230an01 panel
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. As the title suggests, does anyone happen to have by some freak luck some dumps for this TV ? It's a Teletech, doesn't really matter since they're all the same at the end of the day, but most importantly it's got a LTA230an01 panel + 17MB82-2 combination in it and I cannot find a suitable dump. What I tried so far either results in no picture, no startup at all (led blinks 3 times, stops, then again 3 times, etc) or poor picture.
    There's two ICs on there: a 25q64 and a 26q16. From what I can assume, the 16 one is responsible for the panel information, since I flashed that with a dump for a hitachi and that's the closest I ever got to getting it going: the TV came on, but the picture was in negative or had messed up colors, whatever - not the same panel. The dumps I obtained from the original chips themselves are most likely corrupted (which is probably what killed it in the first place), since if I try flashing those, I get the blinking LED situation...
    Any help would be greatly appreciated. Cheers.
    Wattevah...
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Vestel 17mb82-2 dump for LTA230an01 panel
    Not sure if the below info will help or even if passwords still work but this is for the vestel site not sure if will have firmware you need
    http://www.vestelservice.com/VestelS...UserLogin.aspx
    Depending on which one you want
    Argos (Bush, Digihome)
    User VS889106
    password ARG52S
    Luxor
    User VS847338
    password LUX827OR ( that's the letter O in there)
    That should get you in to either site.
    To look up software
    Click brown goods - products - software
    Then enter the set's serial number preceded by the number 2 ie (2)7097437 (taken from the back cover of the set)
    Click search and hopefully they'll have it.
    Also worth noting that clicking on extras in the top menu's will give access to MB, PW and IPS circuit diagrams.
    The site is a bit fiddly to use,But should be extremely useful!..Bit late on this thread,just spotted it!...(User and password must be in block caps)
    • Acca
      • Jul 2017
      • 47
      • Italy
      User VS889106
      password ARG52S
      Luxor
      User VS847338
      To look up software
      I want to thank you for this link, it's very usefull.
      I have a question: here in Italy vestel tv are sold under different names like Telefunken, Philips, Toshiba and maybe more, using the SN from these tv yelds no results, any advice?
      • lberkani
        Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
        by lberkani
        I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
        The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
        The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
        I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
        - Toshiba 65UL2163DG
        - Vestel 17MB180E mainboard
        - Panel VES650QNTX-N2-N42
        - Version V1.28.100.0 if available
        If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
        11-11-2025, 12:37 PM
      • jorpec
        Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
        by jorpec
        Hi, all
        I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
        10-17-2025, 03:51 AM
      • Ancient1
        Before I dump this Panel...
        by Ancient1
        Hi
        I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
        As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
        Right distribution board, 2 Flexs, near them:
        The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
        The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
        I...
        10-23-2022, 11:07 AM
      • howardc64
        LG 49UJ6500 LCD panel lighter band that goes away
        by howardc64
        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
        02-19-2023, 12:13 AM
