Vestel 17mb82-2 dump for LTA230an01 panel
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. As the title suggests, does anyone happen to have by some freak luck some dumps for this TV ? It's a Teletech, doesn't really matter since they're all the same at the end of the day, but most importantly it's got a LTA230an01 panel + 17MB82-2 combination in it and I cannot find a suitable dump. What I tried so far either results in no picture, no startup at all (led blinks 3 times, stops, then again 3 times, etc) or poor picture.
    There's two ICs on there: a 25q64 and a 26q16. From what I can assume, the 16 one is responsible for the panel information, since I flashed that with a dump for a hitachi and that's the closest I ever got to getting it going: the TV came on, but the picture was in negative or had messed up colors, whatever - not the same panel. The dumps I obtained from the original chips themselves are most likely corrupted (which is probably what killed it in the first place), since if I try flashing those, I get the blinking LED situation...
    Any help would be greatly appreciated. Cheers.
    Wattevah...
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Vestel 17mb82-2 dump for LTA230an01 panel
    Not sure if the below info will help or even if passwords still work but this is for the vestel site not sure if will have firmware you need
    http://www.vestelservice.com/VestelS...UserLogin.aspx
    Depending on which one you want
    Argos (Bush, Digihome)
    User VS889106
    password ARG52S
    Luxor
    User VS847338
    password LUX827OR ( that's the letter O in there)
    That should get you in to either site.
    To look up software
    Click brown goods - products - software
    Then enter the set's serial number preceded by the number 2 ie (2)7097437 (taken from the back cover of the set)
    Click search and hopefully they'll have it.
    Also worth noting that clicking on extras in the top menu's will give access to MB, PW and IPS circuit diagrams.
    The site is a bit fiddly to use,But should be extremely useful!..Bit late on this thread,just spotted it!...(User and password must be in block caps)
    • Acca
      • Jul 2017
      • 47
      • Italy
      User VS889106
      password ARG52S
      Luxor
      User VS847338
      To look up software
      I want to thank you for this link, it's very usefull.
      I have a question: here in Italy vestel tv are sold under different names like Telefunken, Philips, Toshiba and maybe more, using the SN from these tv yelds no results, any advice?
      • Ancient1
        Before I dump this Panel...
        by Ancient1
        Hi
        I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
        As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
        Right distribution board, 2 Flexs, near them:
        The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
        The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
        I...
        10-23-2022, 11:07 AM
      • howardc64
        LG 49UJ6500 LCD panel lighter band that goes away
        by howardc64
        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
        02-19-2023, 12:13 AM
      • stav242
        Vestel VES550QNUS-2D Panel issue.
        by stav242
        i just spent quite a few hours trying almost everything i could find out to check why this panel wasnt working.
        MB was detecting a fault and going into fault mode.
        i could se the AVDD go high for a second then drop to off.
        check all CAPs and diodes on bottom buffer boards.
        in the end i gave up and removed the panel, only to find burnt tracks on the cof tab..
        i learnt a lot in the process, but wont go doing all those checks first next time.
        so word of advice... if your panel is suspect, save youself a few hours and check...
        02-28-2023, 11:51 AM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • triplefour
        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
        by triplefour
        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
        tcon is built into mainboard.
        Only one cable goes to panel boards.
        there is a cable from one panel board to the other that links them.
        cost cutting measure that results in us having harder time to diagnose.
        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
        07-28-2022, 07:59 PM
