LCDV2257DVR no audio
  • Amraks
    • Nov 2011
    • 725
    So this tv has tda1517 audio ic
    I have measured voltage on pin 8(stby mute) and there was a tiny amount of voltage say 0.800v
    I traced this circuit to a smd resistor (101)100ohm then following that it goes to another resistor 103(10kohm)
    I then checked the voltage before this resistor which was 16v
    I changed the 10kohm resistor still no sound.
    I then by passed this resistor and had sound.
    the question is how did this even function before the fault?
    is there something I am missing?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LCDV2257DVR no audio
    j
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Can the TV sound be turned On/Off in the menu or Service Menu? I turn mine off and use a surround sound unit.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Please ignore the post#2. I don't know what happened and I got 'J' alone in. What I had before I edited that post was that instead of using a wire jumper to bypass the 103 resistor that reads OK out of circuit. Try placing another 103 across it in parallel so you have 5kohms now and check if the sound is restored.
        • Amraks
          • Nov 2011
          • 725
          if you have the service menu codes for this model teac I would love to see it.
          • Amraks
            • Nov 2011
            • 725
            i get the impression there is voltage missing some where. it might be on the psu I recaped all the secondary caps bar 1 which was a 25v 33uf which I didn't have.
              Can we see good clear pictures of the board and especially around the TDA IC?
              • petehall347
                • Jan 2015
                • 4450
                have you checked the headphone socket ? try headphones plugged in ..sound is turned off on tv with headphones in .
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Sorry but my reply was a general reply. I don't have the same model tv but these functions are available on my Panasonic set.
                  • i_am_patch
                    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                    by i_am_patch
                    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                    04-30-2024, 08:20 PM
                  • Piaskos
                    Dell Vostro 5490 - no sound, no audio device
                    by Piaskos
                    Hi, i've got problem with Dell Vostro 5490.
                    Board - Mantis CML 18788-1
                    Windows says "no audio device detected". The other functions work properly.
                    What i've done:
                    1. I checked motherboard
                    2. I changed audio codec (ALC3204)
                    3. I reflashed bios with clear ME
                    4. Audio is enable in bios
                    5. Both speakers are good
                    6. After installing the drivers from the Dell website, the devices visible in the manager:
                    - Audio for intel displays
                    - Intel Smart Sound Technology...
                    01-30-2023, 02:58 AM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • CapLeaker
                    Motorola Minitor V pager no audio / sound repair
                    by CapLeaker
                    Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
                    Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
                    On the main board of this unit where the speaker connects to there is a metal shield....
                    06-10-2025, 07:44 PM
                  • JRade
                    Audio video receiver KENWood KR-V990D,no sound
                    by JRade
                    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                    I replaced the capacitor C303/0.047F, nothing changes.
                    I'm asking for help, what should I do next?
                    Thanks in advance!...
                    08-05-2025, 10:23 PM
