Hitachi 57F710E Loss of Power???
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    My old Hitachi 57F710E seems to have developed an issue with the power supply.
    Symptoms: After several minutes of being plugged in (powered on or off), the main power supply dies. The green LED at the back of the power supply board just dims slowly... killing and immediatly reapplying 120VAC has no effect. The only way to reset it is to unplug it and wait several minutes.
    It almost seems like there is a thermal cutoff device acting wonky... No bad caps that I can see (all are Rubycon, UCC, or Nichicon, none HM or HN).
    Where to start with this? I don't have a service manual (or so I think, I'll have to check the server).
    sigpic
    (Insert witty quote here)
    Re: Hitachi 57F710E Loss of Power???
    Pictures, pictures, pictures?
    • R_J
      • 9559
      Check the solder connections on DP32 bridge rectifier, they are known to go bad. It supplies the +7 volts and is also for the feedback
      I believe there are two leds, Which one is lit up and goes out and is the other one not on at all? Should be DP40 & DP50
      There are a few fuses (Green protectors), check them, they are labeled EP01, EP02
      EP01 is in the +28 for the convergence ic's
      It's been at least 10 years since I worked on one of these
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        A bad cap on the PSU, perhaps?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Pulled the PSU board. No cracked solder joints and no visibly bad caps. However, one cap did stick out to me a bit; it's a 250V 22uf Nichicon VR, only rated for 89C . If memory serves VR's are known to be trouble. It's also the primary cap for the standby power supply, and from my experience with PC power supplies, usually the standby fails first. hence why only unplugging it would correct the issue. All other caps are 105c rated rubycons, so my hunch is that this cap is fried. My good multimeter is at work right now, so I can't really test it at the moment.
          Of course I don't have any of these magically sitting around, and I'm about to go on a two week work trip to Canada. Lovely.
          sigpic
          • R_J
            • 9559
            If this has the upright power supply board, (HA013xx) is there a 1.8 ohm 5w resistor with a black fuse attached to it, check the fuse, if it's open the relay across it is bad
            The items I was refering to in #3 were on the power/deflection board.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              ^Yup, vertical power supply board, LEDs were on the HV board. Didn't figure that out until I looked closer. The fuse with black marker lines wasn't blown, I think? I'll re-check.
              sigpic
              • R_J
                • 9559
                The fuse (f104) I am talking about should be glued to the 5 watt resistor and looks similar to a to126 transistor
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Nope. The resistor itself is marked as F904, and had nothing glued on. See the attached picture.
                  sigpic
                  • R_J
                    • 9559
                    Is the resistor good? also I do remember replacing relays in these tv's
                    The board (HA01313) I still have around has the fuse mounted to the resistor.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      ^I'd have to check. I'll fetch my meter from work tomorrow (maybe) and test it. I can't find my crappy meter, and I've always kept my good one at work (I'm not testing 480V on a crap meter, I'm not suicidal).
                      sigpic
                      • R_J
                        • 9559
                        Just check the resistance of the resistor, it could be open, and if it IS, there is a 99% chance the relay contacts are also bad (open)
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Nope. Found my crap meter (ok enough for this), 2.1 ohms (nominal 2.2). That was with it soldered and out of circuit.
                          Since I've resoldered many joints (anything that looked suspicious and/or land unplugged many things, I've thrown it back together minimally. Running a stream of music on the chromecast (through the TV, obviously), so far 15 or so minutes in it hasn't acted up. If it makes it for a few hours or so (while I run to dinner), I'll put it back together the rest of the way and figure it was something dumb like a bad board-to-board connection or the like. It did this to me with the HDMI input when I moved into my house last November... didn't like any of my HDMI devices (which are normally fed into it via a mutiplexer) for a week, then started working again. Odd.
                          sigpic
                          • R_J
                            • 9559
                            The current firmware for that set is 0113.0001
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Just died. Audio and everything. I heard relays click.
                              Will see if I can ID a hot area...
                              Is the DP32 on the HV board? I didn't find such on the PSU (just the big one for the main PSU, and the small for the standby).
                              sigpic
                              • R_J
                                • 9559
                                I will recheck the bulletin, it might have been for the other chassis
                                I was looking at the dp47 chassis, yours I believe is the dp55 chassis
                                The power supply that is mounted vertical supplies standby plus a lot of voltages to the signal board.
                                TP01 transformer on the deflection board supplies others for the delection and convergence
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Over the past week I did some testing on the caps on the power supply and signal boards. All passed my testing (capacitence only, I really need to get a proper ESR meter ). I resoldered some other potentially iffy joints... at least one popped which may or may not have meant anything. Put it back together tonight... testing it now. Maybe 10 minutes in at this point.
                                  Note- this is my one week at home... tomorrow I'm back to Ontario for another two week work trip , hence why I'm testing tonight while I can.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Missed this. I updated it when I first obtained it several years ago (curbside freebie). I always update firmware on things as soon as I receive them.
                                    Note- still running a test stream on it... so far, so good... knock on wood.
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      1 hour, no issues. maybe I did fix it???
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        just shut her down... 3+ hours, no reset. Yay?
                                        sigpic
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • navagator
                                          Hitachi 57F710E Power Issue
                                          by navagator
                                          I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
                                          I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
                                          11-09-2023, 06:05 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
