PN60F8500 - Hdmi no signal
  • itelite
    • Aug 2016
    • 124
    Looking at a PN60F8500 Main board number BN94-06205B
    Only HDMI 4 works. 1 2 and 3 will detect but do not display and image. Just gets a no signal message after the time out.
    My prime suspect is the sii9687 HDMi switching chip. I went over solder joints with no change. I am inclined to just change the chip out but the only source i can find is form china with a significant lead time.
    I have searched everywhere for anyone talking about this issue, all i can really find is a few eBay listing for repair services.
    Any chance anyone has any idea what they might be doing in these repair services?
    Ive looked over the data sheet for the sii9687 and it seems dead simple. 4 inputs one output and a few DDC/EDID channels. If i am getting HDMI 4 i have to assume that everything from the output to the display is working correctly. and there is nothing of consequence (as far as i can tell) between the HDMI ports and the sii9687.
    Looking for some thoughts on this, always appreciated of course.
  • R_J
    • Jun 2012
    • 9625
    Re: PN60F8500 - Hdmi no signal
    Have you tried a firmware update? Latest version seems to be (1215.2 Feb 01,2017)
    • itelite
      • Aug 2016
      • 124
      That was a thought as well. After taking well over an hour to download the update, it turns out the tv is already on 1217 via the automatic update. Could not downgrade to 1215 of course.
      Thank you though.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Replacing that IC is a very ticklish job. If you can handle the replacement go for it.
        • itelite
          • Aug 2016
          • 124
          Not too worried about the actual replacement. Just didnt want to tell this guy he has to wait 3 weeks for a chip to get here if i was missing a known issue about this model.
          I will follow up on this thread when the replacement is done for posterity's sake.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Great. Thanks.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4538
              • Italy - Milan
              Hi, it can be not the switching chip, you forgot to say the brand, that is Samsung i guess, the eeprom connected to those ports can be ruined, are you a professional? If you have one programmer , also a few $ one like CH341A, you can copy the content of the port 4 to the others, if it's past 2011 you have the chance that in service menu yo have an item to rewrite them taking data from firmware area. Bye.
              • itelite
                • Aug 2016
                • 124
                Replacing this chip was indeed solution. I had to by a bunch of them from china. if anyone sees these thread and needs one in the US PM me. I cant imagine i am going to use all of them in daily work.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Happy that you got your telly going again. Great job, Pardner!!!
                  • BadHerb
                    • Apr 2014
                    Hi @itelite I just started having HDMI issues and think I might need a chip.
                    • BadHerb
                      • Apr 2014
                      I registered here a while ago - I forget why. I don't think I can message yet since this is my second post.
                      • supravit2000
                        PS4 fat has inconsistent signal after HDMI replacement
                        by supravit2000
                        Hi, guys!
                        I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                        My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                        12-19-2022, 08:08 PM
                      • natiz
                        Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
                        by natiz
                        Following a power surge, the HDMI ports on a UE65MU7003U no longer work, no matter the port or the source - it shows No Signal.
                        The other functions work well (eg Netflix app, etc.), its just the HDMI ports.
                        Is the BN41-02568B board salvageable? Any leads before I open the heatsink cover? board replacement?...
                        09-12-2024, 03:52 AM
                      • Comp_Pro
                        PS5 HDMI not outputting CK/DA Signal
                        by Comp_Pro
                        Hello all,
                        I am trying to repair this PS5 which came in with a shorted HDMI encoder chip. This issue was not allowing the PS5 to boot and would only beep upon pressing the power button. This is the first time I've had this issue despite replacing many many HDMI ports. After installing the new chip as well as a new HDMI port the console now powers on and appears to be booting all the way but there is no video output. Looking at my HDMI tester all signals are present except for DCC Clock and DCC Data aka CK/DA on my particular tester. These two have direct connections to the encoder...
                        10-09-2023, 01:38 PM
                      • jimbofz
                        harwa 42 lcd tv no hdmi signal output
                        by jimbofz
                        theres no precise model number on the rear cover boards labelled as below
                        Hi just been given this lcd tv,
                        ive not come across this make before
                        there is no o/p from hdmi .its fine with scart .
                        good pic for its age
                        the main board is 782 L42W17-690B
                        cant find much info on google
                        to enter service menu .bring up a/v menu ,then 2580
                        but cant move to next page ,for options
                        (i was hoping ther may be an option to switch on/off hdmi/dvi)
                        the reason for this , is when hdmi is selected it says: no dvi signal
                        not: no hdmi...
                        01-06-2022, 05:57 AM
                      • AstutePauciloquent
                        Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                        by AstutePauciloquent
                        Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                        I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                        11-23-2023, 11:02 PM
