Samsung LN46C630K1FXZA no picture or backlight
  • bambinone
    • Jul 2018
    Hi folks,
    I went to turn my LN46C630 off the other night and it only kind of turned off. Power was still being applied to the USB ports (I have a little bias lighting strip) and the backlight stayed on. The TV was unresponsive to remote signals. I let it sit for 20 or 30 minutes before pulling the plug.
    The next day, I plugged it back in and went to turn it on, but it wouldn't turn on. Here's what it does: the standby light blinks a few times, then goes off for a bit, then comes back on. No backlight, no picture (tested with a flashlight). I took the back off and visually inspected the power supply for bad caps—nada. I checked the two fuses on the power supply—both good.
    I ordered a new TCON board from ShipJimmy based on a forum post I found elsewhere, but that didn't solve the problem. I'm glad I found this forum because y'all seem a lot more knowledgeable. I disconnected the mainboard from the power supply and the backlight does come on, so that's good. I tried heating up the mainboard with a hair dryer, pushing on the chips with an insulated screw driver, and flexing the mainboard a bit. Nothing has worked so far.
    Where do I go from here? I have a multimeter but I haven't touched a soldering iron in 20 years. The board is a BN94-02701G; the only replacement board that ShopJimmy has in stock is for the 55" model (link), so I'm not sure that will work. And of course it's not lost on me that if I'm going to spend all this money on new parts I might as well just buy a new 4K HDR TV.
    Thanks in advance!
    Mike
  • thommyX
    • Apr 2016
    • 96
    Re: Samsung LN46C630K1FXZA no picture or backlight
    Mostly the memory is broken. You can trade the EEprom for a blank one. The describes itself the first time turn on again, but with you the BGA itself will be broken. With Samsung, you can change the panel in the service menu and with a little luck, the main of the 55 inch will go with you.
    Greetings Thomas
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Henke
      Samsung TV HG46EB690QB No picture, only backlight when disconnected mainboard
      by Henke
      I came across a Samsung tv that does not seem to start up. When i plug it in nothing happens except that the red led turns on. But when i disconnect the mainboard, the backlight turns on and immediately turns back off when i connect the mb again.
      I have tried to disconnect one, none and both cable(s) from the Tcon to the screen but it makes no differens. The PSU seems to work, but when the mb is connected one of the 5V cycles high and low.
      Anyone with inputs?...
      10-27-2022, 01:01 PM
    • grimreaper420
      Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
      by grimreaper420
      hey guys,
      i bought 2 samsung odyssey g9's for a decent price. they both have the exact same fault. when plugged into a power source, the blue led powerlight shows, but when turned on there is no picture, no backlight, no menu, nothing. when plugged into a laptop the laptop recognises the monitor, but keeps disconnecting and reconnecting.
      dont have any schematics or diagrams unfortunately. any ideas?
      thanks
      09-03-2024, 03:47 AM
    • gl4709
      Samsung un55cu7000d with backlight and sound No Video / Picture
      by gl4709
      I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
      01-23-2025, 06:21 PM
