32lm3400 dead no standby
  • R_J
    • Jun 2012
    • 9535
    Re: 32lm3400 dead no standby
    Replace C504, C505 (47µf/50v) and C506 (10µf/50v)
    • pierce012
      • Oct 2022
      • 6
      • Malta
      #42
      Changed all the ps capacitors before posting here. Supplies are all there. The strange thing is that power led does not light up. Probably something on the motherboard. After 10 minutes the Tv responds to the remote and lights up without any problems.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        Try heating the psu and mainbord up using a hair dryer see if the tv starts up normaly the you can narrow down the area your heating to find faulty area/part
        • nomoresonys
          • 12113
          • U.S.
          #44
          by all capacitors do you mean ALL or just the electrolytics?
          • pierce012
            • Oct 2022
            • 6
            • Malta
            #45
            I mean all the Electrolytics Yes.
            As for the heating I am trying not to go there for the time being. I still haven't solved the hissing sound on the power board.
            • nomoresonys
              • 12113
              • U.S.
              #46
              maybe check C501, C512.
              • nomoresonys
                • 12113
                • U.S.
                #47
                using a hairdryer to heat things up isnt going to hurt anything.
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • piposarcade
                  Samsung UN50KU6300 dead no standby led
                  by piposarcade
                  01-04-2024, 01:33 PM
                  Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                  05-22-2024, 02:07 PM
                • fharris1977
                  Vizio D50u-D1 Dead Set No Standby
                  by fharris1977
                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                  12-28-2023, 10:25 AM
                • max-power
                  Dell E6540 laptop completely dead after dssasembly
                  by max-power
                  Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                  that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                  After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                  03-24-2025, 08:49 AM
                • jacobtc
                  LG C1 65'' dead standby
                  by jacobtc
                  I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                  If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                  If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                  I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                  01-29-2025, 04:27 AM
