32lm3400 dead no standby
  • jonny78
    • Apr 2017
    • 72
    Re: 32lm3400 dead no standby
    thanks budm! resistor is fine! what about the mosfet MDF10N65B ? i cant find this available in the uk is there an equivalent? ill give it a shot with a new mosfet then move on if it doesnt fix it!
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      See if you can find one of the equivalent from the list here
      • groovejet
        • Feb 2014
        • 19
        i know this is a old thread but has exactly what im after, although this thread seemed to of ended quite abrubtly? i guess the guy found what he needed and buggered off? Always good to have good housekeeping...
        • groovejet
          • Feb 2014
          • 19
          if i started my own thread ? How could i link this thread into mine? Without repeating it all?
          • R_J
            • Jun 2012
            • 9624
            Then if everything is the same, and you have 0 volts across the main filter cap, You likely have an open fuse, open TH101 thermistor, or a broken trace between the line in and the bridge rectifier.
            • groovejet
              • Feb 2014
              • 19
              ill look into it today but from what i remember, i have both 3.5vdc lines. Which go over to main board also.
              The fuse is intact and i have 240vac in.
              No standby light,
              Ill have to check the rectifier.
              • groovejet
                • Feb 2014
                • 19
                rectifier reads ok.there is a area ON BACK BOARD NEAR WHERE THE CONNECTOR plugs to take power to main board. There is a selection of surface mounts that look suspect. not burnt but just look dirty .ic202, r205, q201?not sure thats correct last number.
                the ic and the q201 look identical and wouldnt of known they were differant unless board told me so.
                • R_J
                  • Jun 2012
                  • 9624
                  If you have 3.5v standby, you need to check if you have the PWR-ON command from the main board. The PWR-ON pin should change when the power switch is pressed, if it does not I would suspect the main board has a problem.
                  The power supply can be tested seperately if required.
                  • groovejet
                    • Feb 2014
                    • 19
                    ok thankyou RJ
                    • R_J
                      • Jun 2012
                      • 9624
                      If you want to check the power supply, disconnect the cable going to the main board, then find a resistor close to 1k and connect it between 3.5v standby and PWR-ON, this should turn on the +12 & +24v
                      • groovejet
                        • Feb 2014
                        • 19
                        lovely, thats a great tip,ill do that later today
                        • groovejet
                          • Feb 2014
                          • 19
                          going to have to look deeper into this, i havent got 3.5vdc anymore and i measured theb.rectifier and got 120v,110v and no dc volt readings. 120 and 110v are there about, they were few more volts to be exact
                          • Hartk311
                            • Dec 2021
                            #33
                            Thanks for the information on this issue, I believe it to be the same thing I am diagnosing now. I'm new to the site but will be using it as often as issues arise. I appreciate everyone's sharing of knowledge
                            • pierce012
                              • Oct 2022
                              • 6
                              • Malta
                              #34
                              So I have this same problem on an LG 32LM3400. I have got all supplies coming out of the connector but have got no LED on. I noticed a strange constant noise on the PSU even when I unplugged the main board. Any help please?
                              • nomoresonys
                                • 12331
                                • U.S.
                                #35
                                what kind of noise high pitch, low pitch, clicking, buzzing? a little test is put a small hose to your ear and listen to it to try to determine exactly where its coming from, careful not to touch any live sections with your hands, potentially DEADLY voltages on hot/primary side of board.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #36
                                  could use a wooden dowel rod or stick also, maybe use a non conductive same piece of wood to gently tap or nudge the components to see if you can detect it, the component will probably change a slight bit in sound when you find it, also check over your solder joints closely, reflow any that look suspicious, careful not to bridge any joints, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                                  • pierce012
                                    • Oct 2022
                                    • 6
                                    • Malta
                                    #37
                                    Seems like it’s coming from the 3.5v transformer. Eventually the TV started but I am very happy with that low pitch sound. But I will have to recheck tomorrow. Thanks for the time being. Goodnight ����
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #38
                                      ok, might just need to resolder the joints on that transformer.
                                      • pierce012
                                        • Oct 2022
                                        • 6
                                        • Malta
                                        #39
                                        Refreshed the transformer soldering. Hissing/buzzing sound stopped, voltages all present but standby led still off. The TV does not respond to Tv instantly but eventually after 10 minutes it starts. What could it be?
                                        • nomoresonys
                                          • 12331
                                          • U.S.
                                          #40
                                          I might suspect one or both of those 2 electrolytic capacitors there by connector P201.
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • max-power
                                            Dell E6540 laptop completely dead after dssasembly
                                            by max-power
                                            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                            03-24-2025, 08:49 AM
                                          • jacobtc
                                            LG C1 65'' dead standby
                                            by jacobtc
                                            I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                            If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                            If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                            I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                            01-29-2025, 04:27 AM
