bn44-00514a PS component list?
  • znavy264
    • Jul 2018
    • 13
    I've been trying to find out how some of you are able to troubleshoot this particular card without a schematic or list of components and their locations? I need to repair mine, but I just wanted to replace all the electrolytic caps instead of screw around testing them...but then I noticed some other folks had issues with the MOSFETS shorting out.
    So basically I just need to find out what the part numbers/specs are for these components and figure out if I can buy them locally (most likely at Fry's Electronics) or order them online.
    Once again the p/n of the PS card I'm repairing is bn44-00514a, and the card originates from a Samsung 60" 3D Plasma TV (PN60E7000FFXZA).
    Re: bn44-00514a PS component list?
    MOSFETs, Diodes, ICs should have the P/N printed right on the body, so once you get the number then just search to see who has them in stock, you can also look up the spec sheet for them.
    • znavy264
      • Jul 2018
      • 13
      All the MOSFETS in question have this white rubbery glue-like silicone covering them. That stuff safe to remove? FYI it's not Heat Sink Grease.
        The white silicone adhesive? The adhesive is used for holding the component in place during wave soldering process.
        • znavy264
          • Jul 2018
          • 13
          Well I give up. So far all the components look fine (no burns/discolorations/bulged caps). I tested every diode as well and they all seem to work.
          What happens is when I watch TV the screen will go black and the set will turn off (red standby power light also shuts off briefly). Then the TV "clicks" back on (it doesn't make that noise normally). Everytime it did it, the click would get louder and louder. Eventually it was happening every couple minutes which is when I decided to turn off an unplug the TV for good till I could fix it. I just replaced this power supply card in March for the same issue, and now it's doing it again. Maybe I got a defective card? It's just outside of the 90 day warranty (by like a few days). Convenient.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Here is a repair kit and part locations. I would touch up all the major solder points on transformers and anything on a heatsink.
            • znavy264
              • Jul 2018
              • 13
              Thank you for your help TVTimmy. But i've seen this list before and it doesn't give info about the individual components. What I'm looking for is the type of capacitor I need to buy. I can read the capacitance and voltage, as well as the temp, but there are other factors like ESR and Size that come into play that I cannot identify conventionally.
              Also what i'd like to do is upgrade the caps to something more tolerable, for example a higher temp tolerance and higher voltage value (like from 100 to 125). There's plenty of space on the board in case the caps are bigger than what's currently there, but I just want to make sure I'm getting exactly what I need.
              I'm worried the board I already have was repaired using a kit like the one you gave info for, where the caps were low-quality. This could be the reason for the failure after only having used it for 3 months.
              • znavy264
                • Jul 2018
                • 13
                Bump
                  I use PANASONIC FM/FR series for all the repair. Just download the spec sheet from Digikey to get the dimensions and the lead spacing that will fit your board.
                  • znavy264
                    • Jul 2018
                    • 13
                    Wat?
                      Wat?
                      • znavy264
                        • Jul 2018
                        • 13
                        Wat?
                        Hey I figured out what you're talking about now. Sweet thanks for the info. I'm not sure what spec sheet to look at, but the problem is that they do not offer caps rated at 100v, and I have a few like that.
                        • znavy264
                          • Jul 2018
                          • 13
                          bump
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Try Mouser or Digikey
                            • znavy264
                              • Jul 2018
                              • 13
                              I think you guys aren't getting what I'm still trying to figure out....
                              I need help determining the ESR of the caps I need to replace. For example if I were to replace a 100v 470uF 105 degree Celcius cap, I can search for those specific examples on the sites you guys have mentioned so far.
                              But there's an issue....
                              There's like 15 different version of caps with the same specs, except the differences are form factor, lead width, and ESR.
                              The ESR is important because it deals with internal plus external impedance. I have no way of figuring that out because I don't have a schematic of the circuit I'm replacing the caps in.
                              So the ultimate question is....does ESR matter and if so how do I figure out what I need (like how to determine/calculate the ESR)?
                                Do you still have the original caps? Maker of the caps? If you have them then you can look for the spec sheet for them to use as the reference.
                                • HS13
                                  • Feb 2014
                                  • 14
                                  Hi.
                                  Please someone could help me the power board BN44-00515A . Or someone have the schematic power board to check the SMD diode DX859 what's the value then I can replace. On top the body diode numbers B14 224 .can't find it
                                  Please help
                                  • HS13
                                    • Feb 2014
                                    • 14
                                    Originally posted by hs13
                                    hi.
                                    Please someone could help me the power board bn44-00515a . Or someone have the schematic power board to check the smd diode dx859 what's the value then i can replace. On top the body diode numbers b14 224 .can't find it
                                    please help
                                    thanks
                                      What is the P/N of that SMPS IC so we can look up the spec sheet to see how that pin of the IC where the diode is connected to being used.
                                      Can also see the same picture without bad color? It also looks like of the pad is damaged.
                                      We also need the straight shot pictures of the whole top and bottom side of the board.
                                      Is this your board? http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
                                      What is the original problem?
                                      • HS13
                                        • Feb 2014
                                        • 14
                                        On board the IC CX802(3BR2565JF) Pin 2 connect to the diode DX859 (the diode is short).
                                        Samsung PN64E533D2F
                                        I bought the repair kit from ShopJimmy. before I solder. I check some component around the IC then find out the diode is short. May you help me to find the diode ?
                                        I was contact to the Samsung parts. they told me to buy the board .that's is not help.
                                        Thank for your help.
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • flerre
                                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                          by flerre
                                          Hi!
                                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                          So, could I safely assume all of these 3 mosfets are...
                                          03-13-2022, 12:14 PM
                                        • NanoTesting
                                          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                          by NanoTesting
                                          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                          With charger it turns on, fan spins but gives no image.
                                          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                          Reflashed BIOS, same problem.
                                          Replaced both main mosfets.
                                          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                          10-30-2024, 10:48 PM
                                        • debruina
                                          Pioneer VSX-859RDS with all mosfets gone
                                          by debruina
                                          I am working on a pioneer VSX-859. It started with only one problem but i ended up with a lot more. Probably caused by me
                                          Anyway it started with a DSP NG message on the display. That one was easy and was caused by a bad 5v rail. Replaced the capacitors and the message was gone. Everything seems to be working except for a blob sound every time i switched from source. Eventually i tracked that down to a leaking battery on the analog board. Repaired some via's and lines and everything worked ok. That same circuit also caused a not working DCdetect protection. ...
                                          08-29-2023, 11:54 AM
