LG 49LF540V lines
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    LG 49LF540V lines
    Have a 2015 LG 49LF540V that has 1 thin vertical line on right of screen and 1 thin horizontal line across centre of screen, have tried to picture them as best as I can. Have cleaned ribbons and contacts on T con board to no avail, fear it may be a bad LCD panel, any help grately appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 49LF540V lines
    I think you may well be stuck with that 1 line. You could try putting a little pressure on the panel tabs to see if it will go.
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Tried mate, unplugged, cleaned and re plugged everything, wiggled everything whilst on, no change. Such a shame as its a really nice tv n picture is good appart from the lines, as I mentioned only 2015 Tv too!
      • Diah
        • Feb 2013
        • 6614
        this is first age of young panel manufacture , its pixel on lcd it self, no tap or any can fix it
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Such a shame, ill just donate it to someone who needs a TV and doesnt mind the line
          • Syseng
            Lenovo P14s Gen 5 SVP unlock
            by Syseng
            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
            06-22-2025, 07:44 AM
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • joelz
            pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
            by joelz
            Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
            11-18-2024, 06:02 AM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • DrvLikHell
            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
            by DrvLikHell
            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
            The...
            02-05-2025, 01:44 AM
