17ips20
  • newtothis
    • Mar 2013
    • 1556
    • england
    17ips20
    Will get pictures etc later on
    No backlight
    LED Driver only ever goes to 80v and stays at 80v
    Having a hard time figuring which connection is BL_ON
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: 17ips20
    Hope this helps you
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: 17ips20
      Cheers but not really
      Never dealt with LED drivers etc....
      Going to need some guidance....
      I have a schematic for it.... I have tested what i think is BL_ON and reads 0v.... Though cannot be 100% sure it is BL_ON I am testing
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: 17ips20
        To what I know the driver voltage should be at 115v then boost to 180v right?
        Any way of forcing BL_ON?
        • R_J
          • Jun 2012
          • 9624
          Re: 17ips20
          The way to force BL_ON is to disconnect the plug going to the main board and using a 500Ω-1k resistor connect it between standby and BL_ON, you will likely also need a resistor between standby and PS_ON because the main board is disconnected
          If you don't disconnect the main board you risk damaging it
          The voltage to the backlights depends on the panel and how many leds and there configuration
