Need help with figuring out a capacitor on Quadro 5000M from Dell M6500
  • remdale
    • 8
    • Ukraine
    I have a rear video card Nvidia Quadro 5000M, but I broke a small SMD 0402 capacitor on the front side of the card. It's the 2nd capacitor just down the U1 inscription in the left bottom corner of the card. Would anyone having this card please help me measure the capacitance of it? It would require a bit of soldering.
    To those interested in this card: I'm working on replicating it, so you might become interested in buying it from me after I finish. I'm also planning on changing its shape to fit some other laptops.
  • remdale
    • 8
    • Ukraine
    The same capacitor can also be found on GTX 580M, it is attached to the pin 7 of the same MP86963 on the DRAM power rail. The capacitance is 1nF as I suspected it to be. Interestingly, the same chips are also used on the GPU power phases, but no capacitors are used there.
    • Lapsmith
      Fried capacitor on Dell-5520. Guilty as charged.
      by Lapsmith
      While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
      07-06-2025, 11:08 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      DELL Precision M6500 Laptop Schematic
      XM2 Motherboard...
      10-31-2024, 02:22 PM
      DELL Precision M6500 Laptop Schematic...
      10-04-2024, 12:20 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
