Vestel 17IPS62 power supply dead by lighting
  • nomoresonys
    • 12323
    • U.S.
    #41
    Originally posted by Unimatrix
    I have a similar problem: https://www.badcaps.net/forum/troubl...hermal-problem
    Has anyone found out anything new about this?
    If possible, do the same test nebbia88 did by turning backlights way down, if tv works longer then it might be those marginal leds I spoke of.
    • Unimatrix
      • Nov 2023
      • 6
      Thank you very much for this advice! I will check it now and get back to you as soon as possible!
      • Unimatrix
        • Nov 2023
        • 6
        The TV has been running perfectly for a few days with the backlight dimmed. Thanks again for the tip!
        • nomoresonys
          • 12323
          • U.S.
          #44
          Glad to help.
          • Andreas_de
            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
            by Andreas_de
            Hello!
            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
            04-12-2025, 10:38 AM
            03-31-2024, 02:12 PM
          • kevin_allein
            Samsung QE 75 Q 7 FGMTZG Power Supply dead
            by kevin_allein
            Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
            In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
            Does anyone have schematics for that board ?
            Any good tip, what could be the issue ?
            02-27-2025, 12:15 PM
          • khalillll
            maxipower 400W Dead power supply repair
            by khalillll
            The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
            After checking, I replaced the UTC7606D IC to restore the 5VSB.
            I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
            Replaced it again with another UTC7606D.
            Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
            After checking again, I think the issue was with the UTC7520D IC.
            Replaced it with a WT7520.
            Result: PSU fully working again
            09-27-2025, 05:06 AM
          • KYBOSH
            Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
            by KYBOSH
            I have a floodlight-security camera that recently died on me.
            its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
            Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
            07-01-2024, 06:54 AM
