LC60LE830E Error Lamp,No control
  • Jazzotiti
    • Jun 2018
    • 31
    • France
    #41
    Re: LC60LE830E Error Lamp,No control
    Hello
    With the 60le635 keypad, the power supply is woken up with 1 single press on power or the V + key and connecting the power supply.
    V- and (Imput) and power connection gives nothing.
    Probably a problem of interpretation of key sequence, it is not the right keyboard, it could explain.
    you can not really know what the motherboard comprises.
    But it wakes up the cards for a cycle of about 35 seconds.
    I tried to disconnect the lcd tablecloths on the TCon board.
    I tried without the white power connector on the TCon board.
    I also tried without the backlight connector.
    A strange thing and the way flashes lechevron during the PS-on sending phase on the motherboard.
    Should it be fixed bed?
    I controlled the voltages PD connectors
    1.2 Pn12 V = 11.8 volts
    3.4 GND
    5.6 s13 volts = 13.1 volts
    7.8 ur13volt = 13.2volt
    13 ac-det = 3.3 volts
    14 Ps-on = 2.8 volts
    15 BU5V = 5volt
    Here is the video I posted on youtube.
    https://www.youtube.com/watch?v=t6Swu81q2P8
    Cordially
    Thierry
      Can we at least see the pictures of the whole back side of the TV showing how all the boards are connected together?
      Also good clear straight shots of the whole power supply.
      Power supply board model???
      • Jazzotiti
        • Jun 2018
        • 31
        • France
        #43
        Hello again
        For Budm
        I will give pictures of the different cards.
        But you already sent me the diagram of the electrical power supply which is a DPS-183BP-3a.
        https://www.badcaps.net/forum/attach...8&d=1529177005
        The schema is from the site.
        I put pictures of the electronic cards on my second messages page 1 of the site.
        https://www.badcaps.net/forum/attach...9&d=1529079873
        https://www.badcaps.net/forum/attach...0&d=1529079873
        https://www.badcaps.net/forum/attach...1&d=1529079873
        https://www.badcaps.net/forum/attach...2&d=1529146898
        https://www.badcaps.net/forum/attach...8&d=1529208047
        It was concluded a defective motherboard, but with the new motherboard, after 5 ignitions, the card is blocked in protection Lamp Error mode.
        No reset handling woke up the card before the 5 th attempt as after.
        I concluded that the touch keyboard was out of order.
        I connected the one of a different tv but so the 15-pin connector and the like.
        And I arrive woke the original card and to buy card.
        This is the video I posted.
        Otherwise, I made measurements on the L1 connector of the power supply and I have a problem.
        the supply of led strips appears before the disappearance of ps-on about 1.5 sec
        I measure 2 times each section to be of course.
        My mutimeter has a Vmax button
        Pin 1 LED1 +
        Pin 2 LED1- 103 volt
        Pin 3 LED2 +
        Pin 4 LED2-176 volt 2nd control 168 volt
        Pin 5 LED3 +
        Pin 6 LED3- 103 volt
        Pin 7 LED4 +
        Pin 8 LED4- 103 volt
        So I have a problem with the LED strip 2
        For me, the 2 meusres random high of 167 volts and 176 volts volts will indicate an open circuit!
        cordially
        Thierry
        • Jazzotiti
          • Jun 2018
          • 31
          • France
          #44
          Hello ,
          More news ..
          Thanks to my tests on the L1 connector of the power supply DPS-183BP-3A and the anomaly found on the LED2 strip, I decided to connect the socket of the L1 connector of the 60 LE830 to the backlight wires of the 60LE635 I know good and similar.
          By this test, I wanted to make sure that the repair of my backlight was one of the solutions to get to repair my Sharp TV.
          At the start of the tv by the Power button plus the connection of the power cable, Jai at the beginning the same symptome as the video, it flashes quickly for 35 seconds then the light turns on but does not get off.
          The backlight of the 60LE635 will illuminate.
          We can then see by approaching a lamp of the panel of the 60LE830 in the center of the screen and in a frame a message
          "Emission Reception Failure (E202)
          This message is in the center of the panel, so I can say that the panel is working properly left and right and the Tcon card too.
          So there is as I thought for a moment, a failure on the original touch keyboard and a failure on at least one led strip.
          Because of damn HS keyboard, I buy a motherboard because it was impossible to wake up by manipulations' error lamp and other ...
          Here are pictures to better understand what I did.
          https://www.badcaps.net/forum/attach...1&d=1531758227
          Cordially
          Thierry
          • Jazzotiti
            • Jun 2018
            • 31
            • France
            #45
            Hello
            Again, new.
            I replaced the 4 ramps backlight.
            the LED bars are fixed 2 by 2 to an aluminum bar.
            There is only one broken down but it was easier.
            It was late and I wanted to do it quickly.
            I put the one of 60le635.
            I will repair them later when I take care of the 60le635.
            For the dismantling of the slab, I did an experiment.
            For fear of breaking the lcd slab, I laid the slab flat on a rigid board
            and I dismantled all the screws fixing the back panel of the tv to the front part which maintains the screen and the diffuser of light.
            So I removed the set backlight and back panel together.
            The slab did not move, no manipulation on the fragile connectors.
            I just disconnected the Tcon cables.
            The light diffusers remained flat and we were not moved.
            Otherwise, it was difficult to reassemble all properly.
            After replacing the LED light bars, I did the operation in the opposite direction.
            Result, I finally have a visible image.
            Both motherboards work.
            But impossible because of my keyboard of defective origin of return to service mode.
            For Budm, If you read me.
            In the current state of things, it is impossible for me to know if the fluctuation of image is normal or because of a feeding problem.
            Especially since it fluctuates during an extremely precise delay and identical to each start of repetition.
            The tv only starts with a keyboard that does not have his.
            I do not know if my start corresponds to (V- IMput) or something else.
            maybe this change of light for 30 seconds and normal.
            Qund I repaired or replaced the keyboard, I would tell you if there is a problem with the power supply.
            The boot protocol is then reliable.
            Here is a video of the disassembly in accelerate and photos
            https://www.youtube.com/edit?o=U&video_id=KSNul6eme8M
            Cordially
            Thierry
            • Jazzotiti
              • Jun 2018
              • 31
              • France
              #46
              Hello.
              I will tell you that the TV has been working well for about 9 days.
              Usually, I give a true follow-up of the fault solved, but this case is so weird and out of the ordinary that it should not interest anyone.
              I cleaned the pins of the connector going to the infrared detector of the remote control on the circuit board of the tactile keyboard, the TV then restarted by simply reconnecting the tactile keyboard on this one.
              the keyboard works perfectly but I have never managed to enter service mode.
              I have read and watched a lot of videos tutorial.
              But it works without hard reset in a normal way by the power button of the tv or the remote control. we can unplugged and reconnected the TV, it still works well.
              I searched without understanding.
              The purchased card starts only with the 60lE635's touchscreen after about 30 seconds.
              But like for the origin mainboard , it's impossible to enter service mode with the original keyboard of the tv that now works
              It will remain a great mystery.
              Thanks to all the people who helped me and brought information
              Cordially
              • yohnsee
                Semi-noob
                • Dec 2017
                • 198
                • Hungary
                #47
                good to hear that.
                Keep up the good work!
                Cheers, Janos
                • markolino
                  • Mar 2020
                  • 109
                  • Slovenia
                  #48
                  Hi. Am new in this forum
                  A have maybi sam problem whit Jazzotiti or not...
                  A have Sharp AQUOS model: LC-60LE635E
                  And my tv not start on.
                  today i replaced the power board with a working one. The problem still remains.
                  if you could help me i would be very grateful
                  i think it's a flaw on the main board
                  here's my video
                  https://youtu.be/juAvTriU-ms
                  • Yanleb
                    LG 60PK550 Logic Control Board EBR63450301
                    by Yanleb
                    Hi all, I just want to share the repair of my 60PK550-UA TV set.
                    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                    C57: 3.30V
                    C61:...
                    07-20-2023, 12:38 AM
                  • harp
                    triac phase control 0-100%
                    by harp
                    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
                    06-02-2024, 09:00 AM
                  • tmhobadcap
                    Pioneer VSX-522-K remote control not working???
                    by tmhobadcap
                    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                    12-24-2020, 01:44 AM
                    Linear Garage Door Opener Control board took a crap install a new control board back normal
                    by sam_sam_sam
                    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                    02-08-2025, 06:52 AM
                  • crackedprint
                    Sony HCD-HX80R Amplifier Volume Control Problem
                    by crackedprint
                    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                    I have tried a Cold Reset as per the service manual.
                    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                    I have looked all the way through the service manual and tried many online...
                    01-21-2025, 12:18 PM
