Emerson lf461em4 mainboard troubleshooting
  • Eel_dahc
    • Apr 2017
    • 18
    Hi guys, I have an Emerson lf461em4 TV that is dead. I checked voltages as far as I could figure out and the power supply appears to be good. There is no standby light when plugged in. I assumed that I should be seeing a red standby light at the bottom front.
    I have parts from a Dynex DX-32L200NA14 that I had saved away in case I find one with a good screen that I can part swap.
    I noticed that the the mainboards are very different but have the same cable ports.
    Not a wise decision but I went ahead and plugged the Dynex mainboard in the Emerson TV without the LCD cable to see what happens.
    I plug it into the wall and I get a red standby light. Interesting. I can go further.
    Uplugged it and then plugged in the LCD cable, plugged into the wall again, then turned it on.
    Backlights on, I see channel 3.1 on the screen,
    So that told me that the power supply should be ok even though the mainboard is from a 32", the screen works, no cracks, backlights work, buttons work. I pressed menu and it shows the options but of course the screen is upside down and the colors, sizes are way off.
    That's ok, I was just troubleshooting to see what isn't working.
    So the mainboard I assume is my problem.
    I put the Emerson mainboard back in.
    From there I looked up what I could find on the mainboard, I checked the capacitor at C3214 and it is not shorted. I checked capacitor C3832, C3833 and the two small ones there with them.
    IC3601 had 2.5v, the other 1117s had 3.3. I assume it was in standby when I checked it since I get no lights or anything.
    Anything else that I can check?
    EEPROM bad?
    Also, there is a QR code sticker over the serial number and below that sticker is another one with a different serial number. It starts with RS2A. The Original under the QR code starts with a DS2A
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8320
    Re: Emerson lf461em4 mainboard troubleshooting
    Nah, eeprom wont have anything to do with the stand by LED not working. SJ makes a main board repair kit for these( out of stock of course), the symptom it fixes includes a dead set.
    • Eel_dahc
      • Apr 2017
      • 18
      Ok, thanks
      • nomoresonys
        • 12268
        • U.S.
        There's the out of stock repair kit, you could check that diode with your meter, wouldn't it be a nice surprise if it was just a bad diode, probably not tho. http://www.shopjimmy.com/emerson-a3a...lf461em4-a.htm
        • Eel_dahc
          • Apr 2017
          • 18
          Thanks, I'll have to look out for that.
          I checked every part that looked like those in the kit pics, of course no part numbers but just going on the packages and everything seemed ok. The diode though, I wasn't sure about. Might have to lift it and check, because it had readings going both ways but they differed. I am more familiar with schottky one ways.
          • nomoresonys
            • 12268
            • U.S.
            For sure, when in doubt lift it out.
            • handsworth
              • Oct 2015
              • 174
              Hey guys I have this same tv with the same problem as post#1( no power). I also tried a similar main board from another emerson and the tv turned on. So I suspected a main board issue also. Now, I put the old main back in and voila, the tv turned on. Worked fine for 2 1/2 days, then went out again. Ok so I took the back off to listen for beeps and/or get some voltages, but the tv turned on again. Any suggestions whats causing this malfunction?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8320
                cold solder joint somewhere maybe?
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • Michael Long
                  No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                  by Michael Long
                  I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                  Dead / No Power / No Standby Light results after power company had three
                  consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                  After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                  09-13-2022, 06:55 AM
                • noinimod
                  Sony 55X900E no standby light, no power. Replaced mainboard already
                  by noinimod
                  No standby red light, nothing
                  This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                  Disconnected JK3 power board from main board, checked voltages on all the pin outs
                  At a few pins I can see the power supply providing 19.5V to the main board
                  Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                  LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                  12-22-2021, 12:58 AM
                • stylishconsultant
                  un60j620dafxza - Samsung No Display Problem
                  by stylishconsultant
                  Hi All,
                  Need help.
                  I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                  So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                  problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                  might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                  09-04-2024, 03:26 AM
                • Mirenia
                  Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                  by Mirenia
                  I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                  I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                  In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                  The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                  03-30-2025, 06:47 AM
