Sony KDL-46EX523 standby light red, turns off upon power, no blinks
  • SergeSF
    • Jul 2015
    Hello all!
    Dealing with a Sony KDL-46EX523 LED-backlit TV. Upon providing power, the standby LED is red, but when pressing power the LED goes off without any blinking. Pressing power again has no effect (does not go back into standby).
    The power supply is an APS-285. Checked the 12V pins and 3.3V standby, both are present at standby and after pressing power. Caps look fine.
    Hoping someone can shed some light on this
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Sony KDL-46EX523 standby light red, turns off upon power, no blinks
    Does the back light come on?
    • SergeSF
      • Jul 2015
      Not that I can see. I'll test the backlit output and see if anything happens when I first press power. I'm leaning to a bad PSU.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8325
        Could be also a bad main board not sending BLon to the PSU.
        • brithepi2k
          Sony KD-65XE8596 no standby light
          by brithepi2k
          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
          cheers...
          09-06-2025, 02:22 PM
        • matwan
          Sony XR-55X90J 5 blinks
          by matwan
          I have problem with SONY 55X90J. After several check status is as below;
          1. Running power board as stand alone:
          TCON_12V =~ 12.6V
          EVDD V On Max 24V= 19V.
          2.
          Running power board with TCON as stand alone:
          Effect as below, attched.
          3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
          "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
          Best regards....
          09-28-2025, 04:26 AM
        • GoodCapDude
          Sony XBR-75X940E intermittent 6 blinks error code
          by GoodCapDude
          Hi everyone. First post on Badcaps!
          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
          09-20-2025, 06:07 AM
        • Seb932
          LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
          by Seb932
          i'would like to fix my not working LG 49UB850V tv.
          Symptoms:
          -AC plugged in, Standby LED not working
          -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
          Checked already:
          -Powersupply Output in Standby => 3.5V ok
          -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
          Any suggestions what to check next?
          Thanks in advance!
          09-14-2023, 06:28 AM
        • AK_777
          Sony KD-65A1 Repair – 4 Red Blinks Error
          by AK_777
          Hi everyone!
          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
          02-20-2025, 04:15 PM
