COBY Weird Kludge When Taken Off Fried Main Chip On Board
  • Michale32086
    • Nov 2011
    • 1453
    I have never been a fan of COBYs because they are so weirdly designed..
    Got this 55" COBY in. The problem was that when powered on, it wouldn't always come on. When it did, the display went wanky, like someone was pushing a bunch of the buttons (VOL, MENU, etc etc) and then would go off by itself, then come back on over and over..
    I was thinking a wanky MAIN board, but when I cracked it open, I noticed a weird "kludge"...
    As pictured, on the back of the MAIN board and smaller (Driver??) board, there was a 2 strand wire that went from 4 pins on the LVDS connector on the MAIN board to corresponding 4 pins on the LVDS Connector on the Driver?? board...
    Thinking that may have been the problem, I disconnected the wires and the main chip on the DRIVER?? board fried...
    I ordered a new DRIVER board, but am unsure if I should try it without the kludge or not..
    Any suggestions??
  • Michale32086
    • Nov 2011
    • 1453
    Re: COBY Weird Kludge When Taken Off Fried Main Chip On Board
    I should also note that, on the replacement DRIVER?? board, that set of 4 pins are NOT jumper'ed together...
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      The last pic shows the white cable and to me that does not look like a factory installed wire. It would appear to me that this TV was repaired before and some 'bypass' surgery was performed.
      • Michale32086
        • Nov 2011
        • 1453
        Yep, that's my guess as well..
        I just don't know if removing it is what caused the big chip on the DRIVER board to fry or not..
        The board is cheap, so I spose I could try it.. I have a 50/50 chance Fry or NO Fry
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          If it was working before with it there, I would leave it and give the new board a try. Is either it works or it doesn't.
          • Michale32086
            • Nov 2011
            • 1453
            Yea, that's my thinking as well...
            Thanx.. Let ya know in a few..
            • Michale32086
              • Nov 2011
              • 1453
              Hooked it all up and powered up.. Nothing. No LED, no nuttin..
              I was getting voltage on the MAIN board so I looked deeper..
              Looks like a component next to the LVDS connector on the MAIN board got fried as well..
              Ordering a new MAIN....
              Will update..
              Thanx again for the replies..
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                I have a bad feeling about this TV. Especially when it appeared worked on before. Sure you want to spent on it again?
                • Michale32086
                  • Nov 2011
                  • 1453
                  Yea, it's only another $40.. it's a nice 55"...
                  Putting about $70 into it is not too bad, considering I can probably get around $250-$300 in my area...
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    K....
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • JSin21
                      Compatibility of main boards between different variations of samsung MU6100
                      by JSin21
                      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                      I have Samsung Smart TV UA65MU6100WXXY version DA01
                      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                      11-27-2023, 04:54 AM
