COBY Weird Kludge When Taken Off Fried Main Chip On Board
  • Michale32086
    • Nov 2011
    • 1453
    I have never been a fan of COBYs because they are so weirdly designed..
    Got this 55" COBY in. The problem was that when powered on, it wouldn't always come on. When it did, the display went wanky, like someone was pushing a bunch of the buttons (VOL, MENU, etc etc) and then would go off by itself, then come back on over and over..
    I was thinking a wanky MAIN board, but when I cracked it open, I noticed a weird "kludge"...
    As pictured, on the back of the MAIN board and smaller (Driver??) board, there was a 2 strand wire that went from 4 pins on the LVDS connector on the MAIN board to corresponding 4 pins on the LVDS Connector on the Driver?? board...
    Thinking that may have been the problem, I disconnected the wires and the main chip on the DRIVER?? board fried...
    I ordered a new DRIVER board, but am unsure if I should try it without the kludge or not..
    Any suggestions??
  • Michale32086
    • Nov 2011
    • 1453
    Re: COBY Weird Kludge When Taken Off Fried Main Chip On Board
    I should also note that, on the replacement DRIVER?? board, that set of 4 pins are NOT jumper'ed together...
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      The last pic shows the white cable and to me that does not look like a factory installed wire. It would appear to me that this TV was repaired before and some 'bypass' surgery was performed.
      • Michale32086
        • Nov 2011
        • 1453
        Yep, that's my guess as well..
        I just don't know if removing it is what caused the big chip on the DRIVER board to fry or not..
        The board is cheap, so I spose I could try it.. I have a 50/50 chance Fry or NO Fry
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          If it was working before with it there, I would leave it and give the new board a try. Is either it works or it doesn't.
          • Michale32086
            • Nov 2011
            • 1453
            Yea, that's my thinking as well...
            Thanx.. Let ya know in a few..
            • Michale32086
              • Nov 2011
              • 1453
              Hooked it all up and powered up.. Nothing. No LED, no nuttin..
              I was getting voltage on the MAIN board so I looked deeper..
              Looks like a component next to the LVDS connector on the MAIN board got fried as well..
              Ordering a new MAIN....
              Will update..
              Thanx again for the replies..
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                I have a bad feeling about this TV. Especially when it appeared worked on before. Sure you want to spent on it again?
                • Michale32086
                  • Nov 2011
                  • 1453
                  Yea, it's only another $40.. it's a nice 55"...
                  Putting about $70 into it is not too bad, considering I can probably get around $250-$300 in my area...
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    K....
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • Genghis_Khan
                      ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                      by Genghis_Khan
                      I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                      Issue summary:
                      Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                      However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                      11-11-2025, 11:51 AM
