Vizio D40-D1 Totally Dead
  • Michale32086
    • Nov 2011
    • 1453
    Vizio, completely dead.. At plug in or power up, no POWER LED, nothing on the backlights....
    Gonna check voltages, but wanted to ask about this first.. I did check the fuse, which is good..
    In the attached pic, which (if either) is the component most likely to be bad..
    The cap or the resistor..
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio D40-D1 Totally Dead
    I would check/replace them both. I give my vote to the resistor.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The resistor burnt out for a reason. I would check diodes and mosfets in that area. What model power supply is it?
      • Michale32086
        • Nov 2011
        • 1453
        Full pic
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Now that I can see the whole picture.
            That is the resistor for the Source pin of the power Q8100 MOSFET that drives the primary winding of that T8100. The SMPS IC that drives the Gate of that MOSFET may be damaged when the MOSFET shorted out..
            • Michale32086
              • Nov 2011
              • 1453
              Thanx for the reply..
              I went ahead and just ordered a replacement board.. Seemed to be the path of least resistance...
              • Iain P
                Vizio E65-F0 really dead
                by Iain P
                Hi everybody!
                I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                I decided to check the voltages coming off the power supply they are as follows:
                connector CN201
                pin 1 (18vsb1)...
                02-23-2023, 11:32 AM
              • phantomEVO
                [help]lenovo thinkpad 16s gen 2 TOTALLY DEAD
                by phantomEVO
                Hi to all! thinkpad p16s gen 2 totaly dead. i have only 5v on both ports.
                pd controller is tps65994
                i don't know where to start: could you help me? thank
                Schematic & Boardview - https://www.badcaps.net/forum/troubl...atic-boardview
                09-13-2025, 02:16 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
