Telefunken Vegas 42" plasma TV not starting
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi guys. I have another set with a very unusual fault. When inserting power to the set i notice that after a few seconds the standby light starts flashing rapidly but there is no picture on screen. You do hear a relay click in, thats all. I found many caps bloated, some other with high esr. I changed about 15 caps on y-sus, x-sus, psu and main av board. This made no difference. I then stripped the tv until i got to the logic board and noticed the following. Upon powering up the set, the led on the logic board makes one quick flash... then comes on continuously for about 4 seconds and goes off permanently. The VS-ON pin going to the PSU does activate for about 4 seconds. Va = 55, Vs = 205 and Vscan = -190. These are all spot on according to plasma label. I checked all fuses and two green micro fuses and they are good. I checked all mosfets on y-sus and X-sus and y buffer... could not see any shorts. I then checked voltage regulators on main av board. It has two LM1117 regulators both being supplied with +5.2V. One steps diwn to 2.5V but the other steps down to 3.16V. I thought this to be strange and replaced the LM1117 with another one but got the same 3.16V. The output of the LM1117 measure in the kilo ohm range so no short there.
    What i notice is that the tv starts up but the logic board shuts down the y and x boards. Some error i cant identify. Is there something else i can check or test?
    Kind regards
  • R_J
    • 9624
    Re: Telefunken Vegas 42" plasma TV not starting
    The LM1117 is available in 1.8v, 2.5v, 3.3v, 5v, and adjustable version. they are not interchangeable
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Yes i know, on the above mentioned tv it uses the two resistors which control the ADJ pin on the voltage regulator. It's just a bit strange at which it controls the voltage.
      I still can't make sense of where to look for a fault. I might take oscilloscope readings on the y buffer board and see if i get the correct waveforms.
      It has Yfr and Yrr test points.
      • R_J
        • 9624
        When you first turn the tv on, do you get the precharge flash, the whole screen should give a slight glow for a few seconds.
        Maybe post the model number
        • angelos
          • Dec 2012
          • 573
          • South Africa
          No. There is nothing. I did not notice any flash
          • angelos
            • Dec 2012
            • 573
            • South Africa
            I spoke to a friend of mine that suggested i replace all electrolytics on the main board. He had weird symptoms and it turned out to be a 100uf cap whose ESR measured fine but the capacitance was way down. I will keep you all posted on the progress of this one.
            • R_J
              • 9624
              If you have a scope, use it to check the caps, if you see a lot of high frequency ripple its not doing its job and is liklely bad.
              • angelos
                • Dec 2012
                • 573
                • South Africa
                Hi R_J, yes i went back to the main AV board as suggested by a friend of mine and replaced the rest of the electrolytics. You cant believe it but when the cap is connected in circuit the ESR value is good but take it out and you get 27 ohms. After replacing all the caps the TV started up and i could tune the RF channels. There is still a problem though. It seems some times when you start the tv the screen remains blank as before except that the standby light does not flicker anymore it stays a solid green color. I now need to investigate what exactly is not starting up. Will keep you posted on the progress.
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  Just an update. After replacing all 26 caps on the main AV board the sets starts up correctly when its been running for a while but on cold start up the Vs volts And Vs-on volts from logic board fall away after the sets power button is pressed (4 seconds) and the sets sound starts without a picture. If however you put the set into standby and again on then it starts up properly and runs.How do i go about determining where the fault originates from. What would happen if i force the Vs-on pin going to the power supply when set is cold. I really dont want to blow mosfets. Has anyone done something like that?
                  • R_J
                    • 9624
                    That does sound like a bad capacitor, it could be a small one on the power supply for the vs supply, or maybe on the Ysus board. When you first apply power if the cap is weak it won't keep the supply running, but the next attempt the cap has not completely discharged and still has enough capacity to keep the supply running.
                    This happens in smps when the cap that keeps the vcc supply runing from the secondary gets weak.
                    Usually its a small cap like 4.7 -47uf 50 volt that goes bad and they don't look bad. Maybe like that small cap near the VS-ADJ control
                    Im not sure but this schematic might be close?
                    • angelos
                      • Dec 2012
                      • 573
                      • South Africa
                      Thanks R_J. I dont know how i never ended replacing that cap but check the picture i attached. This 22uf 50V cap had a above 100 ohm esr reading. I had loosened the one point of the cap to measure it reliably but never changed it. I have subsequently replaced it and am waiting for tomorrow morning when its really cold to start it and see what happens. Check pic.
                      • R_J
                        • 9624
                        That cap seems to be for a small smps ic that supplies a few voltages on the ysus
                        • angelos
                          • Dec 2012
                          • 573
                          • South Africa
                          After a cold start this morning i realised that it was the cure. Done and dusted. I replaced 32 capacitors on this set. Whew.
                          • R_J
                            • 9624
                            Good to here, so that one fixed it. many times its those little ones that give trouble, they dry up and don't have enough electrolyte to leak or bulge so get overlooked.
                            • angelos
                              • Dec 2012
                              • 573
                              • South Africa
                              Yeah. I did measure it but must have been distracted and ultimately forgot to replace it.
                              • angelos
                                • Dec 2012
                                • 573
                                • South Africa
                                Hi all. This set came back after 3 months with the same problem. To summarize, on power up the psu clicks on and Vs and Va are correct and there is no pre charge flash nothing... I need to measure with my scope to see if the y or x panels are working. I would like to know when measuring on these boards where do i connect my scope ground terminal. I will upload later pictures of the boards so that you can see. Do i connect to chassis ground?
                                • angelos
                                  • Dec 2012
                                  • 573
                                  • South Africa
                                  Any help, any body???
                                  • angelos
                                    • Dec 2012
                                    • 573
                                    • South Africa
                                    Anybody with plasma repair experience able to run me through this set?
                                    I even shorted pins 3 & 4 on Z board (TCON) and i get nothing. Dont have waveforms or any info to help me diagnose where the issue is. Heeeelp.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      Post a picture of the logic board.
                                      ------------signature starts here------------
                                      • tranquility
                                        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                        by tranquility
                                        i want to repair an Onkyo TX-NR809 receiver.
                                        symptoms:
                                        on power on, display appears and i hear one click. enue functions is given.
                                        - no hdmi output
                                        - audio output not tested, but i think it is not there
                                        - usb sticks are not recognized
                                        if i read out the chips with display+standby button + tone+
                                        both dts show only ????
                                        chip is D830K013BZKB4
                                        things i have done:
                                        - reflow of the dts chip without taking off and reballing
                                        - changed the aluminium caps without the big one with 25v because i dont...
                                        08-25-2025, 01:04 AM
                                      • classypenguin
                                        Need Dump - Telefunken D43F500M4CWI
                                        by classypenguin
                                        Hello, I have a Telefunken D43F500M4CWI mit Vestel 17MB181TC Board in for repair. The TV turns on, shows the multimedia panel with wrong time setting, then no signal and the remote control doesn't work either. Whether hard reset nor factory reset function without remote control. Are there a firmware or auto flash via usb available for this TV? If this is the case, I would like to get some guidance, because I don't had an Telefunken with programming in yet.
                                        Thank you 😀
                                        10-20-2024, 03:11 PM
                                      • ArMaaN376
                                        Samsung PS51E550 Plasma TV
                                        by ArMaaN376
                                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                        Opened TV cover & observed foll
                                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                        How to confirm Y -Buffer board...
                                        06-19-2024, 04:05 AM
                                      • jm1234
                                        Panasonic plasma TX-P42ST50 - 6 blinks
                                        by jm1234
                                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                        I checked that board for any obvious faults...
                                        05-22-2024, 06:59 AM
                                      • KYBOSH
                                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                        by KYBOSH
                                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                        No picture but you hear the TV static (white noise) playing loud and clear.
                                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                        But it seems they didn't get too far and just left it.
                                        When I first took a look I was amazed at how pristine the inside looked.
                                        Its as if the TV had been in a time capsule.
                                        Caps looked like they were just pulled off the self.
                                        Copper coils had no sign of corrosion on...
                                        02-01-2023, 11:10 PM
