Sharp LC32D44E-BK backlight issue
+ More Options
Posts
  • mitsukiso
    • Sep 2017
    • 31
    • Италия
    Hi guys!
    i've changed lamps on Sharp LC32D44E-BK (as far as google says it's the main problem of this model) and made the error reset. The TV worked fine for some days and turned back to the same problem. at some moment the lamps turn pink and then shut off. i've opened the tv to see the state of lamps and they seem fine. The transformators seem fine as well, have +- the same resistance.
    what could it be? bad contact with lams? should i solder them?.. i really like this TV, the image is much better than modern ones
    Thank you!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp LC32D44E-BK backlight issue
    Not having the TV in front of me and not posting any pictures for us to see, I would give a guess to either the wrong type backlight lamps were put in, bad lamps or bad Inverter if the lamp ends do not show any evidence of HV arcing.
      Originally posted by mitsukiso
      Hi guys!
      Thank you!
      All the lamps light up pink, or just one lamp? CCFL when lights up pink is the sign of bad lamp. Are they new lamps or used lamps?
      • mitsukiso
        • Sep 2017
        • 31
        • Италия
        @budm they all appear pink, thats strange. all lamps are new, taken in china, but i think all spare parts are made there, so.. may be bad contact? may be the connectors got loose in years?
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          The service manual is available from here
          Do you have 60V @ fuse F7501 and also +13V and +9V on the inverter board when the lamps go pink in the event that one of the voltages are dropping.
          The manual also says on the inverter board connector Lamp Error = 0V and Lamp OK = 3.2V
          • Cornito
            Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
            by Cornito
            Hello Team,
            I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
            Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
            Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
            08-08-2024, 08:09 AM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • Cornito
            TCL 65C715 backlight issue
            by Cornito
            Hello team,
            I'm back with another topic.
            It's a 65C715 TCL tv with backlight issue.
            But the problem is a bit strange.
            When I took this tv from the marketplace backlight didn't work but picture was ok.
            Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
            Putting all back together the tv worked fine for weeks. => Contact issue??
            Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
            06-09-2024, 02:24 AM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
          • shellybelly
            Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
            by shellybelly
            Back Story
            I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
            So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
            08-27-2023, 10:40 PM
