Panasonic Plasma fault
  • boomtheroom
    • Apr 2018
    • 28
    • new zealand
    Hi All
    Ive got A th-p50vt30z plasma was going perfect till it got the 7 blinks of death
    so i replaced the faulty suspected transistors with some cheap ebay ones
    tv went for a few hours the Pop blew up again.. after seeking advise was pointed to a reputable source so got more transistors and replaced those
    now tv turns on to a solid green light ,displays some garbled writing for a split second and stays a black screen
    still faulty board or had something else got damaged in the process?
    link to video.. sorry if its a bit dark
    https://www.youtube.com/watch?v=Ys6T...ature=youtu.be
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic Plasma fault
    Make sure all screws are in and check wire and ribbon connections.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      You still have a faulty board because you used cheap ( fake! ) parts from ebay. They indeed work sometimes ( for a few mins ) and go out with a bang and damage the board even more.
      I had the same problem , never fixed the board....
      • boomtheroom
        • Apr 2018
        • 28
        • new zealand
        nah replaced the cheap parts with good ones..still no go..
        • boomtheroom
          • Apr 2018
          • 28
          • new zealand
          yep done that several time to make sure.. still same problem
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            The cheap parts that blew up did more damage to the board. I cant find that model number here in the USA to look at a pic of your board.
            • boomtheroom
              • Apr 2018
              • 28
              • new zealand
              hers a pic
              • boomtheroom
                • Apr 2018
                • 28
                • new zealand
                any idea what the voltage should be at sc2?
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Yup but you used fake parts on the board which resulted in more damage to the board. I see you used the FGD4536TM to replace the bad parts.
                  The problem with bad parts is that they cant handle the load and literally blow up and take out other parts in the same trace.
                  In europe the voltage should be around 215V on the prong connector.
                  There are more parts defective on the board , could be a resistor but you need to measure every single part......
                  Could you check for shorts on the SS board?
                  • WildPuppy
                    • Mar 2018
                    • 61
                    • Romania
                    I had a short private chat with @boomtheroom before he started this topic and I tried to help him since he had the same problem as me: bought a kit, worked for some time and blew up again.
                    I suggested the replacement with FGD's from monitor09 and he did that.
                    I support @Morenos83's advice to re-check everything on the board(s). It is very possible that you have some resistor or capacitor out of spec and it messes with the end result.
                    Also, don't forget to clean the screws, screw pads and TV chassis contact points as leaving any of them scorched will get you into trouble again, fast.
                    • boomtheroom
                      • Apr 2018
                      • 28
                      • new zealand
                      will do.. all the other boards seem to be ok ... no shorts. getting the power they should no bulging caps.. so will revisit the sc board
                      • WildPuppy
                        • Mar 2018
                        • 61
                        • Romania
                        That's the way to go. It would help you a lot if you find the proper schematic for your TV or board and check the values of the resistors against the schematic values.
                        Check all diodes and transistors, including those smaller ones that are not "power parts".
                        • boomtheroom
                          • Apr 2018
                          • 28
                          • new zealand
                          Took the board out retested resistors, diodes ,transistors.. couldn't find anything so put back in and turned on .. now getting 6 red flashes?????
                          • boomtheroom
                            • Apr 2018
                            • 28
                            • new zealand
                            found a short on one of the white plugs that connects to the lower buffer board bit of stray solder was shorting 2 pins..removed that reconnected now i get this!!!
                            • boomtheroom
                              • Apr 2018
                              • 28
                              • new zealand
                              anyone ever seen that before?
                              • boomtheroom
                                • Apr 2018
                                • 28
                                • new zealand
                                https://www.youtube.com/watch?v=IH0O...ature=youtu.be
                                • boomtheroom
                                  • Apr 2018
                                  • 28
                                  • new zealand
                                  Just found a couple of cracked ics r5207a and c08n25 the first tests ok still but the latter is open on all legs..are there any good or better chips to replace these bot with?
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    Dont know , you probably need the original ones.
                                    I also ordered the fgd4536tm from monitor09 but mine look different from the originals....im afraid to use them.
                                    Do you have a picture of your FGD4536TM? A non soldered one...
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      You will need to use the original parts for replacement. Moreno, I told you to buy the fgd4536 from "the guy". I have never had a problem with any of them. I have a 55" up on my buddies wall, at his tavern, that is running 14 hours a day on max brightness. I can send you a pic of mine to compare to yours if you need.
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        Yes Timmy please do so. I ordered the same and mine look completely different then the ones i had before....
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Eaglecrest
                                          Panasonic plasma color stripe
                                          by Eaglecrest
                                          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                                          11-05-2025, 06:16 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Lintesir
                                          Panasonic P42S30 Plasma - Pink sparkles
                                          by Lintesir
                                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                          There is about a 5cm high region at the top without any sparkles,...
                                          07-26-2024, 03:16 AM
