slow led?
  • Newbie123
    • Oct 2015
    • 58
    • uk
    slow led?
    Hi all i have a led strip and when tested one of the leds is slow to start up on the strip,it reaches the same brightness as the other leds,it just takes a very small amount of time longer to start up,it is wise to use this strip or not?,
    i presume this is a sign that this led might fail soon?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8150
    Re: slow led?
    I think you answered that question yourself. So if you don't feel comfortable with it and you don't want to open up that TV anytime soon again, get a different strip or that particular LED.
    • Newbie123
      • Oct 2015
      • 58
      • uk
      Re: slow led?
      Yeah i think so and good point its a technika tv and i have no idea how i got it apart without cracking the screen it was the hardest led screen iver ever opened up,it makes the vestel ones look easy!,thanks for backing up what i thought.
      • adelage
        220v Led strip flickering
        by adelage
        Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
        I know that the best solution would be to get a voltage...
        11-03-2024, 09:49 AM
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • benareeno
        Adjustable dc power supply and tcl led strip
        by benareeno
        I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
        I have an adjustable dc power supply and was trying around 9 volts.
        I have a pic of a single diode...where to put pos and neg terminals to light it up?
        Pic of middle of strip..is this where i light the entire strip?
        And pic of end...or does this light the entire strip?
        Where to put pos and neg for single diode..multiple diodes and the entire...
        07-11-2021, 02:31 PM
      • mikey5791
        Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
        by mikey5791
        Got this working ips led monitor by the brand of
        Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
        Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
        09-04-2023, 03:50 AM
      • gjlpereira
        MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
        by gjlpereira
        Hi forum.
        I'm working on a macbook pro, model a1708, that is running extremely slow.
        Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
        One other symptom of the problem with the machine is that the fan is always running at full speed.
        This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
        09-06-2022, 07:45 PM
