Samsung Plasma PN63C550 Replaced Y-SUS Voltages Good, Then Drop
  • Michale32086
    • Nov 2011
    • 1453
    Got in a Sammy PN63...
    Initially, voltages were all over the place at power up.. Determined it was the Y-SUS.. Replaced it with a probable good one...
    Now I get Sammy Startup Tones and voltages are good. But nothing on the display panel and voltages drop like a rock after initially reading GOOD...
    No obvious bad caps and fuses all check out..
    I was thinking Power board, but don't think I would get good voltages initially if the Power PCB was toast...
    Control board??
  • Michale32086
    • Nov 2011
    • 1453
    Re: Samsung Plasma PN63C550 Replaced Y-SUS Voltages Good, Then Drop
    Speaking of the Control Board..
    It has an LED that has a pattern when the TV is turned on.. 6 sec on, 3 sec off, 6 sec on, 3 sec off, etc etc etc...
    There are also a pair of jumpers that, if I remember right, can be used for diagnostics??
    • R_J
      • 9588
      Your plug CN2006 on the control board is NOT seated properly. The leds indicate temperature and indicate the board is working
      • Michale32086
        • Nov 2011
        • 1453
        DOH!!! Thanx...
        • Michale32086
          • Nov 2011
          • 1453
          Fixed it.. Didn't change anything..
          One thing I noticed.. Normally, when you power up the TV, the Power LED blinks a couple times and then goes off and the TV comes on..
          IN this case, the Power LED stays on...
          • mmartell
            • Oct 2013
            • 3189
            You mean doing as R_J suggested fixed it or something beyond that ?
            • Michale32086
              • Nov 2011
              • 1453
              I fixed the issue that RJ pointed out.
              Unfortunately, it didn't fix the problem in the TV..
              Due to the Power LED not functioning normally (stays on after TV powers up) I am leaning towards the Main Video Board...
              • Michale32086
                • Nov 2011
                • 1453
                I have an opportunity to buy all the parts for this TV sans the Power PCB for $100....
                I think I am going to go for it cuz it doesn't look like a Power issue...
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Buffers or Xsus....
                  TELEFIX
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Freeze that IC under the wafer to the right of the yellow transformer on the ysus. Then immediately power up. See if you get picture. I believe this is an infinion IC tjat controls VSCAN
                    • Michale32086
                      • Nov 2011
                      • 1453
                      I'll check that, once I get the LG off the bench... Thanx...
                      • Michale32086
                        • Nov 2011
                        • 1453
                        No luck..
                        I froze the marked component and still got the same.. Sammy tones, no display...
                        The replacement parts should be here Thu... As long as the problem is not a bad Power PCB, I should have this up and running by Thu.
                        Thanx for the reply...
                        • Michale32086
                          • Nov 2011
                          • 1453
                          OK Looks like the problem was the Y-SUS board...
                          I got the gamut of parts from this model.. All but the Power PCB...
                          Replaced the Main.. Nope.. Still no go.. Replaced the Control Board and then X-SUS.. Nope...
                          Replaced the Y-SUS... Ahhhhh Houston, we have a picture!!
                          So, then I reversed my steps and put all the old boards back in... X-SUS, Control Main... All good..
                          Thanx for all the replies.. Chalk this up as another win...
                          • debidoobs
                            RX580 all voltages good but won't boot and fan won't spin
                            by debidoobs
                            Im actually trying to find what is going wrong with my sapphire Pulse RX580 8gb... I purchased it used and supposely dead a year ago and found out (thanks internet) that U1000 (And gate sot23-5) was not giving me the high state to the power management IC NCP8122...
                            At this time, with no spare parts, i decided to put a 1kohm resistor to create the voltage as commented by a guy named Lorkur on this forum (https://*******/viewtopic.php?f=48&t=122873), you ll need to translate it in english.
                            and voila ! the gpu worked again and i didn't care much since....
                            02-11-2024, 02:04 PM
                          • SoporteHR
                            LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
                            by SoporteHR
                            Greetings to all, I hope you are well.
                            I consult you because I have a problem with this power source.
                            The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
                            When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
                            I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
                            but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
                            06-20-2023, 04:30 AM
                          • divingfe
                            LG Plasma 50PA5500. Sound, no picture !!
                            by divingfe
                            Sorry if this is too repetitive, or in the wrong place.
                            I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                            I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                            06-19-2021, 06:36 PM
                          • Capacitorial
                            Powersupply has all the voltages - Monitor still no power
                            by Capacitorial
                            Hello guys,
                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                            The weird thing is, that the Power LED is powered over the TCON board.
                            On The TCON...
                            12-28-2024, 02:12 PM
                          • rabbituk
                            Sony HCD BX7700dbi CMT flashing standby
                            by rabbituk
                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                            02-11-2025, 05:05 PM
