Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
  • kevinm34232
    • May 2012
    • 1884
    Re: Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
    I think I may know what's going on and I don't know why I didn't see this before but when hitting power button, when POWER ON goes high momentarily, BL-ERR is going to 3.3V as well, which would explain 5 blink code, not T-Con problem but a panel issue.
    The thing is I've tested backlights with back light tester and can force PS on with POWER ON and BL-ON and seems normal.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      #42
      On e-bay there are 'used' Main Bd. (I checked) they are supposedly from TVs with broken screen. I buy ALL my boards off e-bay and have had no problems thus far. They are reasonably priced. Yes I do think it is a Main Bd. issue.
      • kevinm34232
        • May 2012
        • 1884
        What about the BL-ERR?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          #44
          Well the backlights came on and stayed on when you tested the PSU so I think a Main Bd will fix your TV.
          • kevinm34232
            • May 2012
            • 1884
            Where are you seeing used boards for this model?
              • 12274
              • U.S.
              #46
              Originally posted by kevinm34232
              Ya not spending that much on an older 46", not worth it.. thanks for looking though..
              Budm as for the PANEL ERR#:
              On initial plug in to AC and/or each time power button is pressed, pin goes to 0.872V, then drops quickly back to 0V.
              The same thing happens if I disconnect CN4002 (the other LVDS connector), or either one or both of the ribbons going to the panel.
              With the T-Con completely disconnected from main board, PANEL ERR# goes to 3.3V immediately.
              Not sure what to make of that voltage reading whether it should be low or high..
              I tried grounding out the 3.3V PANEL ERR# pin with the T-Con disconnected, same 5 blinks.
              I hear ya, I wouldn't pay half that for it.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #47
                OK so this was the board I saw. I didn't realise till now the others I see are saying defective for 27.00USD
                • kevinm34232
                  • May 2012
                  • 1884
                  Any clue what triggers the panel_err this is really I can find about this..
                  • budwich
                    • Jul 2015
                    • 3097
                    you might check this thread AND the suggestion by davi.p
                    https://www.badcaps.net/forum/showth...t=69505&page=2
                    • kevinm34232
                      • May 2012
                      • 1884
                      Follow up on this one, got another main board and fixed it.
                      Neither the BL-ERR or PANEL-ERR voltages changed from before, so it was just a main board false error. Maybe EEPROM?
                      Toshiba TC58NVG2S3ETA10
                      Oh well giving up on this one, not worth the trouble..
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        #51
                        Thanks for the follow up. So it WAS a faulty Main Bd. after all.
                        • brithepi2k
                          Sony KD-65XE8596 no standby light
                          by brithepi2k
                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                          cheers...
                          09-06-2025, 02:22 PM
                        • iglitare
                          by iglitare
                          09-04-2025, 07:13 AM
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • thelankanguy
                          Sony KD-55X9000F TCON Issue
                          by thelankanguy
                          The TV shows a black screen with no image.
                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                          Later both ribbons were disconnected and TCON voltages were tested.
                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                          There is also a short to ground in this circled inductor.
                          Is this a TCON issue or something else ?...
                          12-13-2024, 12:27 AM
                        • GoodCapDude
                          Sony XBR-75X940E intermittent 6 blinks error code
                          by GoodCapDude
                          Hi everyone. First post on Badcaps!
                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                          09-20-2025, 06:07 AM
