Samsung plasma PA43h4100 power issue
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hello friends, I have this TV when I power on red light blinking even the ctrl board blink green but the TV will remains black screen, when I test va and vs no 58v and 208v only m5v is available. Please help
  • Cooperr
    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
    by Cooperr
    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
    10-21-2025, 01:11 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • lp20th
    Samsung Plasma TV Power Supply Issue
    by lp20th
    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
    11-28-2023, 10:28 AM
  • CDNBrewer
    Samsung Plasma PN43D450A2D No Power
    by CDNBrewer
    Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
    This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
    I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
    When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
    03-02-2025, 04:59 PM
  • Cookybaby
    Samsung UN60ES6500FXZA Power Supply Issue
    by Cookybaby
    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
    Make: Samsung
    Model: UN60ES6500FXZA
    Power Supply P/N: BN44-00525A
    Symptoms: The TV was...
    08-20-2023, 12:26 PM
