Samsung UN55eh6070fxza
  • oval_97
    • Jan 2017
    • 3
    With the help of threads on this forum I've repaired a couple of TVs and monitors and been using them quite successfully. Up until now they've all been power supply issues so I don't have a lot of experience with image quality/panel issues.
    Recently I found a un55eh6070fxza on the side of the road. I was surprised and hopeful when it powered on, but as the picture came up realized why it was in the trash. At first the picture looks semi-normal. Some fuzz on the lower left side, and the displayed text looking like every other horizontal line is missing. Then it quickly dissolves into a white screen, with a thickish horizontal line across the bottom, black spot in the top right corner, and a doubled image.
    Youtube link:
    https://www.youtube.com/watch?v=jTX1...ature=youtu.be
    I'm happy to do preliminary troubleshooting, but I've read that horizontal lines typically mean a panel problem so I thought I'd post here before I started tearing it apart and checking voltages to save myself the trouble if it's not economically feasible to repair.
    Thanks for any help!
  • CapLeaker
    Leaking Member
    • 8158
    Re: Samsung UN55eh6070fxza
    either a bad tab bond, driver or a bad panel, I'd say.
    • oval_97
      • Jan 2017
      • 3
      Thanks for the input. When I get a chance I may try pulling it apart and pressing on the tab bonds and see if that makes a difference. With your lead I did some googling and It looks like Samsung may have had an issue with these and some people have had success using a taped pad on top of the bonds. Worth a shot...
      • CapLeaker
        Leaking Member
        • 8158
        Also clean all these ribbon cables.
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
          09-07-2024, 05:50 AM
        • kotel studios
          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
          by kotel studios
          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
          Yesterday, 02:07 AM
        • yankys
          Samsung 75"QN75Qn90AAFXZA Horizontal line
          by yankys
          Hi, everyone this 75" has horizontal lines and jittering I did a visual check on the ribbon cables and reset them still same results it will work for awhile then reboot and play again, could it be a main board given that the t-con and main board are one....
          01-29-2023, 09:17 PM
