60PB5600 Control board EBR77186601 test jumper
  • goldbird78
    • Feb 2018
    • 188
    • canada
    Anyone know where the jumper test points are ? I'm thinking R651 & R652. See picture. Thx
  • R_J
    • 9624
    Re: 60PB5600 Control board EBR77186601 test jumper
    Thats close, its the two holes labeled EXT_AUTO_GEN. some people solder a 2 pin plug then use a push on jumper similar to the ones on pc motherboards.
    • goldbird78
      • Feb 2018
      • 188
      • canada
      Got it
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
        Linear Garage Door Opener Control board took a crap install a new control board back normal
        by sam_sam_sam
        I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
        02-08-2025, 06:52 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • redoxy
        Control Board Replacement for 2K display
        by redoxy
        I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
        The display is Samsung LTM270DL07.
        I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
        I am looking for inputs on what board could potentially be used for my display.
        Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
        Also attached is a technical...
        03-14-2023, 08:52 PM
