Re: Panasonic 27" Picture Problem
Well I've FINALLY got a bite here.
First off I lifted pin 40 and powered the TV up no change. There was no short between pin 40 and the trace it has about 35 M ohms or so of resistance. So I soldered the pin back down.
The manual did have voltages for both the neck protector transistors.
The neck protector transistors:
Q451: Manual Voltages
B: 0.59
C: 0.00
E: 0.00
Actual On Board
B: 0.663
Q452: Manual Voltages
B: 0.00
C: 2.49
E: 0.00
Actual On Board
C: 400mv Building up to this then falling down to around 200mv and restarting again.
I think this is what's dragging down the line and causing the IC to blank out.
Q453: Manual Voltages
B: 0.00
C: 8.65
E: 0.00
Actual On Board
C: 8.69
The spot killer transistors:
Q605: Manual Voltages
B: 4.23
C: 0.00
E: 4.21
Actual On Board
B: 4.12V
E: 3.93 It slowly rose to this voltage
Q606 Manual Voltages
B: 0.00
C: 3.63
E: 0.00
Actual On Board
C: 4.08 V
I also checked the line that the neck protector and spot killer connects into the bold line and one end leads to the power supply transformer. I measured across C560 a bipoloar lytic and got around 4.96 volts with the TV in standby and 4.05 with the TV on.
The IC datasheet says for pin 40:
0.0 - 1.0 RGB off
1.6-3.0 Normal
I did consider supplying it externally with my digital bench supply but decided against it.
So it seems that the IC is getting blanked most likely because of Q452 but why wouldn't it be receiving the proper collector current?
Now it's personal with this thing
B: 0.59
C: 0.00
E: 0.00
Actual On Board
B: 0.663
B: 0.00
C: 2.49
E: 0.00
Actual On Board
B: 0.00
C: 8.65
E: 0.00
Actual On Board
C: 8.69
B: 4.23
C: 0.00
E: 4.21
Actual On Board
B: 4.12V
B: 0.00
C: 3.63
E: 0.00
Actual On Board
C: 4.08 V
0.0 - 1.0 RGB off
1.6-3.0 Normal
