Samsung LN37A550P3F
  • Super360
    • Jul 2016
    • 243
    Re: Samsung LN37A550P3F
    hey guys i have a kinda off topic question but if there is a place for another cap but there was never put in can i add one to improve the circuit or just leave it alone?
      Those are Rubycon so they may be OK, but one way to find out is to at least test the capacitance and the ESR of those caps.
      • Super360
        • Jul 2016
        • 243
        Ya i already decided to replace every cap anyways just do to age and it being almost 9 years old anyways and i dont have a esr meter need to get one. -thanks
        • Super360
          • Jul 2016
          • 243
          Just a little update got the shop jimmy repair kit and got it all installed just waiting for the caps now also the cap and little ic was simple the audio ic was a motherloving bitch though here's some pics. I had to get a exacto knife to see if any pin would move to make sure it was soldered and had to worry about the smallest solder bridge but its all good now.
          • neilc6
            • Nov 2015
            • 1550
            I wouldn't have replaced the audio IC. Repair kits always have more parts than you need. You could end up causing more damage or introducing new problems.
            • Super360
              • Jul 2016
              • 243
              yea was not smart on my part and i will need to scavenge a 470ohm resistor as i knicked it when screwing with that ic.
              • Super360
                • Jul 2016
                • 243
                ok just a little update shes all fixed up now thanks for all the help everyone also if anyone attempts this repair probably dont change audio ic, its a bitch to install.
                  09-07-2024, 05:50 AM
                • C152Heavy
                  by C152Heavy
                  Summary for TL-DR readers:
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • sansanpartida
                  Samsung QE82Q70RAT no backlight
                  by sansanpartida
                  Hi everyone!
                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                  My issue: No backlight.
                  Model: QE82Q70RAT
                  Type No: QE82Q70RAT
                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                  So hopefully, I can fix this cheaper.
                  05-22-2024, 06:56 AM
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
