SAMSUNG PN58A550S1F Power Supply Cycles
  • Sparkchaser15
    • Jan 2017
    Hello Guys and Gals, I am looking for some help on a Samsung 58" Plasma.
    When the unit is plugged in it seems to go thru a normal startup, the screen flashes quickly, a normal start up sound comes from the speakers then the relays click, it goes into shutdown and cycles back on again and continues to repeat the cycle.
    Visual inspection on top and bottom of all boards look good.
    No bulging caps or bad solder connections.
    Standby and run voltages test good until shutdown.
    Checked all power supply caps with my old ESR meter with no luck.
    Random checks on the power supply transistors with a DVM all test good.
    Unplugging various boards seem to have little to no effect except the main panel(tuner/sound etc.) but I am thinking that is what is calling for power on?? Please correct me if I am wrong on that. I am currently going thru a learning curve, been out of the game for awhile.
    Any help on this would be greatly appreciated.
    Are there any sources for schematic diagrams out there? I have searched with no luck.
    Thanks in advance!
    Never Stop Learning!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: SAMSUNG PN58A550S1F Power Supply Cycles
    Maybe c102 on the bottom of the mainboard? I dont know if this model has it.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Need good clear straight on pictures of back of tv with cover off and each board. Should be a way of putting tv in test pattern If you have this main board there is a repair kit for it. BN41-00975B
      • Sparkchaser15
        • Jan 2017
        Bad solder joint on C102. Set is working great now. Thanks for the tip.
        • dskall
          • Oct 2016
          • 2905
          • usa
          If it happens again. You will have to change it. Lots of failures.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
          • Cookybaby
            Samsung UN60ES6500FXZA Power Supply Issue
            by Cookybaby
            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
            Make: Samsung
            Model: UN60ES6500FXZA
            Power Supply P/N: BN44-00525A
            Symptoms: The TV was...
            08-20-2023, 12:26 PM
