Any Panasonic Viera lcd tv experts?
  • Gdog215
    • Mar 2018
    • 29
    • Usa
    Hello, I have a tc-L37s1 with a steady red standby light that won't turn on.
    No video, audio or backlights. When pressing power I get a click and a red light no blinking and a black screen. First Panasonic I've tried to fix.
    You live and you learn right?
    Re: Any Panasonic Viera lcd tv experts?
    Service manual:
    You need to find out if the main board is sending the PS-ON signal to turn on the power supply board or not, so look for the power supply on signal pin on the connector between main and power supply board.
    BTW, are you trying to fix it down to component level (including SMD type), or changing boards?
    • Gdog215
      • Mar 2018
      • 29
      • Usa
      Either or as the boards for this tv are still kind of pricey, probably will use just as a spare room tv. Because the resale will probably be low. The component level fix will seem like a challenge I might try though.
        Well download the service manual and read it, that will be the starting point.
        So you do have tools, correct?
        How much times and studying are you willing to spend?
        • Gdog215
          • Mar 2018
          • 29
          • Usa
          A lot as I’m laid off as a systems pos pc technician looking for full time work, I’ve already fixed 3 TVs this month, waiting for my friends income tax so I can unload. Got the tools meters and rework station and am fascinated with these damn TVs. Will study the service manuel. Thanks Budm
          • Gdog215
            • Mar 2018
            • 29
            • Usa
            Upon researching this tv I found that there is a small sq101 bulb on the power board. I read disconnecting the 2 backlight connectors from the power board than powering on the tv. Looking at this bulb seeing if it lights up or not would determine if the problem were the backlights or power board itself. Mine did not light up, so I'm thinking issue with the power board. Also noticed a big yellow component on the power board looks slightly burned. Maybe a transformer?
            What do you guys think? Maybe buying a cracked power board same part number for cheap and replacing this part? Included pictures
            • R_J
              • 9588
              Is the fuse that supplies the inverter section ok?
              • Gdog215
                • Mar 2018
                • 29
                • Usa
                Yes the fuse tested good
                  https://www.badcaps.net/forum/attach...8&d=1524071481
                  That is power transformer for switched power supply that will be turned on when PS-ON is present.
                  What DC Voltage when measure right between the two legs of the main filter cap (the big large cap laying on its side) when power switch is activated?
                  BTW, you have 3 power relays (RL101, 102, 103) on that power supply/inverter board, do ALL three of them click on at all?
                  Panasonic N0AE3FJ00002 Power Supply for TC-L37S1
                  http://www.shopjimmy.com/panasonic-n...pply-unit.htm#
                  Pictures provided by shopjimmy.
                  • R_J
                    • 9588
                    Have you checked the voltages on P2, page 28 ofthe manual lists the pin# and what the voltage should be. when the power button is pressed you here the relay so standby voltage must be ok at least. Have you tried shining a flashlight at the screen to see if there is any image (you may need to press the menu button to get an image if its not on a working input)
                    • Gdog215
                      • Mar 2018
                      • 29
                      • Usa
                      I really need to brush up on my meter testing skills on a live tv, as I’ve been shocked before while playing around with plugged in tv power supplies. This tv has been sitting in my basement for some years as career got in the way. But a hint when I first bought the tv was told that it needed a new transformer. Will try to check the flashlight trick and check for the menu and get back to you guys.
                      • Gdog215
                        • Mar 2018
                        • 29
                        • Usa
                        Went to check voltages on p2 but noticed when the tv is plugged after awhile clicks and the red light blinks 13 times. The service manual says 13 blinks is emergency sos comm error between ic 8007 and ic 1102, check point a board. Flashlight trick pressing menu still black screen. Used my Apple TV with screen mirroring through iPad no picture or sound. Unsure measuring voltage on p2 connector, never saw a connecter like that on a tv attached as picture. Also tried to test voltage on the big cap dc voltage was 516 volts if I did it correctly.
                        • Gdog215
                          • Mar 2018
                          • 29
                          • Usa
                          Update it was the main board 13 blinks per service manual comm error 8001 ic chip
                          Thought maybe bad cold solder joints on chip. Applied flux to sides of ic chip than heated it up for 10 minutes evenly. Powered it on and boom. Working tv
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Good job!!!
                            • tvdoctortv
                              • Jun 2018
                              • 3
                              • Moldova
                              I got Panasonic TX-LR32E3 with 13 blinks. Heating up the processor with hot air gun ( 400 Celcius for 40 seconds) did not make any difference). Do I have to heat it up for a longer time? Trying to fix A-board to a component level. Also read that the flash memory may be the culprit. Any help in solving this problem is greatly appreciated. A link to a service manual, troubleshoot guide, etc. for this model will be very helpful. I got this TV as a gift and would really want to upgrade my CRT to a HD standard.
                              Measured PS voltages are 5,7V, 16V, 24V. On A board I got sub 3.3V, sub 5V, sub 1.5 V, sub 1.2 V - all OK. CPU is MN2SW0177. It looks like I don't have 2.5V and 12V out from DC/DC converter IC4150 BD81021. I could not find the datasheet on this IC. My intuition tells me it's either CPU or Flash memory, but would love to confirm it, if possible. Thanks for any help.
                              P.S. TV behaves as follow. After plug into AC no light comes on. When pressing "turn on" button the green light flashes for about 10 seconds then goes to steady green, but nothing comes up on screen, no BL neither, no sound. It stays like that for 5-7 minutes, then red 13 blinks comes up.
                              • tvdoctortv
                                • Jun 2018
                                • 3
                                • Moldova
                                BudM, would you please help me with a link to a service manual or troubleshooting guide for Panasonic TX-LR32E3. Thank you
                                • yohnsee
                                  Semi-noob
                                  • Dec 2017
                                  • 198
                                  • Hungary
                                  Sorry to bother, but you may want to have a look at this manual:
                                  https://elektrotanya.com/panasonic_t.../download.html
                                  Here the model nr. ends with 30 not with 3, see for yourself if it can be useful.
                                  EDIT: As always, pcb modell numbers and display type would help us a lot.
                                  Cheers, Janos
                                  • Alicat
                                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                    by Alicat
                                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                    Model number is TH-50PZ85U
                                    Power comes on and the red power light stays on solid.
                                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                    I also hear a few clicks.
                                    I also think my parents said there was a thunderstorm and the TV failed after that.
                                    Section 6 in the service manual talks about power and no screen,...
                                    10-30-2024, 10:09 AM
                                  • waakye
                                    Panasonic Viera tv P46st30 no standby light
                                    by waakye
                                    Hi guys,
                                    I have this Panasonic plasma tv which exhibit a no standby led. I read through a few posts and even bought a new A board from eBay and the set still has no standby light. I am measuring standby voltage of 4.99vdc at P6 pin 6 on the P board. Any help will be appreciated.
                                    Photos attached.
                                    Thanks in advance...
                                    01-16-2021, 01:08 PM
                                  • mostachio
                                    Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                    by mostachio
                                    Hi Badcaps,
                                    I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                    TV Details:
                                    Model # - TH-65DX700Z
                                    Symptoms:
                                    The television turns on and displays a picture then makes a clicking sound and turns off.
                                    I haven't opened it up yet but...
                                    09-04-2024, 02:32 AM
                                  • Noah Glasse
                                    LG 50PK590 - three clicks and steady red light, won't turn on.
                                    by Noah Glasse
                                    I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                    I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                    02-24-2025, 07:23 AM
                                  • Ama Chur
                                    Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                                    by Ama Chur
                                    After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                                    02-21-2025, 08:12 PM
