Vizio D500-Bi No Backlight - Sorta
  • keithsipa
    • Apr 2018
    • 7
    • usa
    Hey all,
    I am by no means an electronics technician, but more of a jack of all trades. That being said, I am looking for some experts in the field to help me out with what I should be doing next to troubleshoot.
    I have a Vizio D500-Bi that if unplugged or not turned on for a while (1 hour perhaps) it will start and work fine, until it is turned off.
    Once the TV is shut off, it will not turn on again, however the stand-by light will light up and there is 5v at the stand-by pin on the power supply. If I try to turn it on immediately there is no sigh of life at all, other than the the standby light illuminating.
    If I unplug the TV for 10 or 20 minutes. Then try to power it on, the big V will appear for a very short amount of time on the screen, then the screen will go black. There is no blacklight, and when I try the flash light test, there does not appear to be any image on the screen.
    If I leave the TV unplugged for a while (around an hour or longer) the TV will turn on and work as normal. Then the same thing happens again, if I turn it off.
    I have disassembled and looked at the power supply and main board and there are no obvious signs of any problems on any of the boards.
    What are the first steps to take. When I had the back off of the TV, I had probed the voltages at the power supply to the mainboard, the standby voltages were a steady 5v, pins 15 and 16, pins 11-14 seemed to be running around 15V while the TV was working fine.
    Any help would be appreciated guys.
    Re: Vizio D500-Bi No Backlight - Sorta
    Check PS-ON (command signal from main board) pin when TV is working and when it is not working, <1VDC = main power supply off, >2V = main power supply is turned on.
    I would suggest you to read basic troubleshooting guide.
    • maxvalutech
      • 804
      • australia
      Sounds like a PSU problem (not turning on) and this can be due to itself or to main board not sending turn on voltage signal when warm. Follow budm advice and particularly how main and PSU are supposed to interact together at start up.
      • keithsipa
        • Apr 2018
        • 7
        • usa
        Will do guys. I appreciate the response.
        • keithsipa
          • Apr 2018
          • 7
          • usa
          Thanks for the suggestions guys. Went through the basic threads, then found these 2 posts with very similar issues.
          https://www.badcaps.net/forum/showthread.php?t=59376
          https://www.badcaps.net/forum/showthread.php?t=54991
          Did some followup testing when working and not working.
          In working condition, here is the power supply pins:
          When the TV is in a non working state, here is the pins:
          It would appear that it is normal to have 15V on the 24V rail on this set.(at least from the experience of the other posters) However, it would also appear that the problem is in the generation of the 15/24V. I am leaning toward trying a replacement power board.
          PS- it appears I got the model wrong in the title if someone can edit.. It should be a B500i-B1
          • keithsipa
            • Apr 2018
            • 7
            • usa
            Anything else you suggest I check.
            The boards for these are not widely available, so I want to be pretty sure.
            The only other thing I was thinking was to remove the LED driver cable from the power supply to make sure that something else is not drawing down the voltage.
            • CapLeaker
              Leaking Member
              • 8327
              If you look on your main board top left corner, there is another small power supply there too. A bunch of caps and 2 fets. So unplugging the LED's from the main board won't get the effect desired.
              If memory serves me right, a few years ago there was an issue like this on bad caps. I think the back light driver is on that main board, not on the PSU. You have to do more testing for sure to figure out what is causing what here. I think you found the thread already.
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • bunting78
                Vizio D650i-B2 wont trun on and no standby light
                by bunting78
                First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                09-23-2021, 08:53 AM
              • shovenose
                Christmas Light Power Supply Question
                by shovenose
                I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                12-08-2023, 09:59 AM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
