Vizio E320-B2 dead help
  • ivtec
    • Dec 2008
    • 1967
    Hi good people long time no see hope everybody's fine ;I'm trying to save this Vizio E320-B2 from land filed; I plug the tv push power switch or remote control the white light lights up for a second then goes out and stays out no back light,These 2 boards,Power and main boards that's all i see,don't see any Tcon.
    Re: Vizio E320-B2 dead help
    May be bad EEPROM: http://www.shopjimmy.com/vizio-e320i...eprom-only.htm
    You should at least test the Voltages on the power supply connector that goes to the main board to see what Voltages you for the power supply and the control signals.
    • ivtec
      • Dec 2008
      • 1967
      Thanks budm for the tip,i'm going to check the main board since caps, resistos, fet, reg, diodes, on power supply test good.
      This Vizio it's not same modle but was fixed by a eprom replacement,but the only difference between my vizio it starts up with pic and logo,mine doesn't show anything no logo nothing
      https://www.youtube.com/watch?v=zcsDkK-WYpk
      • Bull40dawg
        • Apr 2015
        • 4
        How did you repair your Vizio ,ivtec? I have the same model and same problem,any help would be greatly appreciated!
        • ivtec
          • Dec 2008
          • 1967
          Well i did not yet,simple because i don't need it,i really have many tvs don't want to spend any money on the Main board or Eprom if i trusted Ebay,but i don't; cause i was burned a couple times
          • Iain P
            Vizio E65-F0 really dead
            by Iain P
            Hi everybody!
            I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
            So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
            I decided to check the voltages coming off the power supply they are as follows:
            connector CN201
            pin 1 (18vsb1)...
            02-23-2023, 11:32 AM
          • catnapped
            Dead Vizio D40u-D1
            by catnapped
            Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
            04-02-2024, 08:55 AM
          • fharris1977
            Vizio D50u-D1 Dead: PSU or Main Board?
            by fharris1977
            Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
            03-12-2024, 12:22 PM
          • fharris1977
            Vizio D50u-D1 Dead Set No Standby
            by fharris1977
            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
            12-28-2023, 10:25 AM
