Sharp LC-40LE810UN Blinking Code 2 slow-5 fast
+ More Options
Posts
  • SevenOFF
    Denon AVR-X4000 – Fast red blinking after 2nd relay
    by SevenOFF
    I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
    According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
    Here’s what I’ve done so far:
    • Fully opened and cleaned the unit (a lot of dust inside)
    • Removed and visually inspected the AMP board → nothing visibly damaged or burned
    • Testing is done with
    06-18-2025, 09:54 PM
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • Umadbro
    Dell Inspiron 3481 (EDI72 LA-G714P) Powers with charger blinking code
    by Umadbro
    Hi, I've been given this laptop which upon plugging the charger it produces a blinking code, and it goes as follows:
    "3 AMBER, 5 WHITE"
    Pressing the Power Button, the machine seems to power up, as the fan spins (at a normal rate), but after a few seconds the power cuts off, and the cycle repeats.
    Searching on Google for the blinking code for this device doesn't return any valuable information. The code is not listed on the service manual. However, I found out that for others or similar models "3 AMBER, 5 WHITE" blinking code...
    01-18-2022, 06:38 AM
  • bajdik
    Sharp LC-40LE830E white blinking after wallplug is off
    by bajdik
    Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
    07-21-2023, 09:05 AM
  • joblo37pam
    Sharp LC-80LE844U Blinks 2 slow, 5 fast
    by joblo37pam
    It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
    The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
    10-26-2023, 02:17 PM
