2011 sylvania lcd tv stuck in channel scan mode
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Very odd....turn tv on and it just shows preprogrammed channels scanning in upper right corner
    No picture
    No buttons on tv respond other than power
    Now...if i hit and hold power button the channel scan stops and the picture comes but once i let go of power button tv powers off and when powered back on the channel scan continues
    Any ideas?
  • shelby5041
    • Feb 2009
    • 1505
    Re: 2011 sylvania lcd tv stuck in channel scan mode
    Im going to take tv apart tomorrow and check the channel power button board....
    Seems to be common on sylvania emerson lcd tvs ...
    • R_J
      • Jun 2012
      • 9588
      You could have a bad channel button, try unpluging the board with the push buttons from the main board and see if the scanning stops.
      If the buttons are across the resistor ladder, if one button goes resistive, it can activate a function, ie: channels scanning, volume going up/down, menu poping up etc.
      • shelby5041
        • Feb 2009
        • 1505
        Thanks ill try tomorrow.....
        • shelby5041
          • Feb 2009
          • 1505
          tv is working now rj
          took tv apart and took power button board out and just toggled channel down button about 100 times and now it works
          may be faulty //sticky....but seems to be ok now....tv powers on fine and no ghost channel scanning anymore lol
          • shelby5041
            • Feb 2009
            • 1505
            one question though...with power button/ir board disconnected how would you be able to power tv on??? if tv is on and you disconnect the board from main would tv still stay on ?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I would replace all those micro-switches with new ones if they are as they do become faulty after a while.
              • shelby5041
                • Feb 2009
                • 1505
                thanks but the tv not a tv i use just one i got for free
                so as long as it works now thats all i care about..if it does it again in future i would then replace board or the switches....the board on this tv is hard to find and very expensice...$25
                normally these power button boards are on ebay for well less than $10
                that tells me its a common issue...on this model tv....using this boARD
                • R_J
                  • Jun 2012
                  • 9588
                  These buttons should be easy to find, check your scrap. or order new ones. If it is just the one button, then remove it and use the remote. Also once the tv is on, if you unplug the board the tv will stay on.
                  • shelby5041
                    • Feb 2009
                    • 1505
                    thank you
                    did not know the buttons were universal?
                    i have tons of scrap power button boards.....and am not fmialir with removal procedure...will have to look into it if i decide to do that but for now tv is working fine so ....but good to know for future use during troubleshooting
                    i appreciate the knowedge
                    • nomoresonys
                      • 12272
                      • U.S.
                      I put a drop of 90% isopropyl alcohol on the buttons and work it in.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        Yes. The micro-switches are universal. IPA is OK but I prefer to use a drop of WD40 or LPS 1 or any such light penetrating lubricant.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          Thanks....
                          • spleenharvester
                            Reverse engineering of 18650 4-channel tester
                            by spleenharvester
                            Hi friends
                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                            05-04-2025, 02:43 AM
                          • Stunt
                            Hp Laptop Stuck on Hp protected by hp sure start screen
                            by Stunt
                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                            screen that's it and stuck there. I left it until the following day and i still...
                            09-02-2025, 01:51 PM
                          • mikey5791
                            Help on car amplifier only one channel works
                            by mikey5791
                            Hi all forum members,
                            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                            08-06-2025, 10:36 PM
                          • dicky96
                            American Audio VLP1500 Distorting on one channel
                            by dicky96
                            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                            Protection and Clip LED are off
                            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                            07-13-2022, 05:25 AM
                          • sima112
                            Marantz pm 6005 right channel not worknig
                            by sima112
                            Hi guys,
                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                            01-30-2023, 12:11 PM
