Good day folks. I thought I'd share with you a little something that's happened to me which I haven't seen so far and to also ask for a little advice in the process. I received an LG TV (can't remember the model right now since I'm writing from home and didn't snap a picture of it, that's why I said "coming soon" in the title bar) with dead backlight. Simple enough I thought. I took off the panel to access the LEDs and started testing them one by one....none of them would come on ! NOT ONE ! A couple of them were visibly burnt, showing black stuff under the lenses, but the others seemed clear enough, yet they refused to even shine a little. Thinking perhaps I'm putting my supply's probes in the wrong places (though it's certainly not the first TV of this kind I'm messing with), I took my meter and measured in continuity mode: I'm reading shorts across the end contacts of all 3 LED strips. No wonder the test supply was not doing anything - it was just shorting out, since it's just a small 5v AC adapter, without any meter or indicator, so I couldn't tell what it was doing. ALL LEDs dying in a TV like that ? That's a first if I ever saw one...I can't begin to imagine how it could've happened for one thing and second I'm a bit reluctant to replace the strips, fearing there's something wrong with the PSU and it will fry those too...what do you guys think ? Strange am I right ? :\ Cheers.
LG TV (model coming soon) with ALL LEDs dead ?!
Re: LG TV (model coming soon) with ALL LEDs dead ?!
You have shorted LEDs in all strings or maybe PCB damage on the strips, so the strips most likely need replacement. Doubtful it would be caused by the PSU of the TV, they're just overdriven from the factory, and people leaving the TV at the same settings it was put at in the store doesn't help, either. But after you get it repaired, a small modification to the LED driver to limit the maximum current would be a good idea, ensuring this doesn't happen again.Last edited by Th3_uN1Qu3; 03-29-2018, 09:47 AM.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
A short on the very ends of each strip would imply that all LEDs in that strip failed shorted...sometimes they fail open, which wouldn't read a short, at least not on the ends.
I've seen people talking about modifying the output of the LED driver but haven't really looked into it myself and haven't done it before. My knowledge of electronics would tell me it's done by changing the value of some resistor divider which sets the output current the supply is trying to reach....just a guess.Wattevah...Comment
Is there protection diode on each LED strip?Never stop learning
does this set use the 3v or 6v version leds does seem odd all failedComment
Take a look at the underside of the power supply board. See if they use a BD9483F as the led driver. Also check for loose solder joints on some of the electrolytic capacitors.
I've fixed two LG 50LN5400-UA sets with some bad leds.
If you search for the data sheet on the above driver ic you will find that they have a formula to calculate the current flowing through the led strips. The value of the sense resistors determine the current allowed. I increased the value of the resistors to lower the strip current.
The board that I modified was EAX64905501 (2.1).
I don't want to suggest that this is a fix as I don't have data to support it.
I did not notice any reduction in the brightness that affects viewing after I did the modification.
MikeComment
I have a 49 inch LG right now that has 25 out of the 50 LEDS blown! I believe these are the 6v ones. They have the wide angle lenses on them that like to fall off. Unbelievable. Rubbish.Did I leave the soldering iron on?Comment
Replaced the strips in this TV and it works perfectly. The problem turned out to be one of the LEDs on the bottom strip puncturing a hole through the strip and arcing on the metal chassis below.....or so I think....anyway. Case closed.Wattevah...Comment
by edugimenoHi There!
Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I... -
by KingfreddieOk.. this is the story:
Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
This is kinda how it looked, just that mine were at the bottom of the screen:
by smortSoooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had... -
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by lmcancuHi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
Instead of putting it back together I decided to replace... - Loading...
