Samsung UN60EH600 UN55EH6000 Identical Problem
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung UN60EH600 UN55EH6000 Identical Problem
    Not THINE sorry. It's the ISL9860 most likely bad.
    • Michale32086
      • Nov 2011
      • 1453
      Yea, and replacing that is way above my paygrade..
      The replacement TCON for the U55 was $15... The replacement TCON for the U60 is like $115...
      Life ain't fair..
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Oh come on. A $100 hot air station and a $20 flux can are all you need. And the flux will be good for 1 year if you keep it in a cold place.
        A working TV? How boring!
        • Michale32086
          • Nov 2011
          • 1453
          I am getting on in my years.. My hands ain't as steady as they used to be..
          • CapLeaker
            Leaking Member
            • 8325
            my hands are fine, no problem there.... BUUUUT my vision is going to the crap heap.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              same as, im 50 this year and get odd hand shake issues also eye sight getting worse using reading glasses now but hey wont stop me from doing repairs just yet.
              • Michale32086
                • Nov 2011
                • 1453
                OK, update...
                Speaking specifically to the UN55EH TV...
                I have replaced the Power PCB, the Video Main PCB, the TCON, the LVDS Cables and the tab connectors that go from the TCON to the Panel PCB...
                Nothing works.. I still get the tones, the backlight, but nothing on the display panel..
                By process of elimination, that leaves the Panel or Panel PCBs as the issue..
                Anyone else see another possibility???
                • CapLeaker
                  Leaking Member
                  • 8325
                  that lil board where the tab bonds are on? Maybe a cap or so is shorted?
                  • Michale32086
                    • Nov 2011
                    • 1453
                    I pulled the front bezel off and inspected the Panel boards... No burns or blemishes.. All looks perfect...
                      • 12274
                      • U.S.
                      #30
                      OK, update...
                      Maybe the replacement mainboard was bad? quite a head scratcher, looks like you replaced most everything.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Yea, I have like 4 or 5 Main boards.. While it's possible that they all are bad/incompatible it's not likely.. Would be nice if I had a working model that I could swap parts over... which happens more often than ya might think...
                        But not this time.
                        It's one of those ones I usually just put aside until I DO get a working one in..
                        Unfortunately, it's a customers and I am under a time constraint.. Like today..
                        Sucks to be me...
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Something that may or may not mean anything..
                          When I put in the replacement MAIN board and the replacement TCON board, when the TV powers up, there is no backlight.. No latent image, of course, but no backlight either..
                          When I disconnect the LVDS cable from the MAIN or TCON, I get the backlight...
                          I dunno if this is just indicative of an incompatibility or something more meaningful..
                          • CapLeaker
                            Leaking Member
                            • 8325
                            check the LVDS with the oscilloscope, turn the menu on and off all the time while probing the lvds.
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              #34
                              Did you watch the video I gave you the link too? In there he shows the voltages before and after repair. The t-con you bought is probably bad also as they are known to blow the little buck converter on them.
                              Proud owner of dozens of broken TV's and many,many,many boards.
                              Our website and passion:http://hollenhundshepherds.com/
                                • 12274
                                • U.S.
                                #35
                                https://www.youtube.com/watch?v=yTnkOfwBGGE Testing video, good test there, says bad panel will take out good t-con.
                                • CapLeaker
                                  Leaking Member
                                  • 8325
                                  that is true. But in his case I think one of the new boards is a dud.
                                    • 12274
                                    • U.S.
                                    #37
                                    http://www.shopjimmy.com/catalogsear...?q=+UN55EH6000
                                    Maybe check that t-con matches panel numbers and check that all boards are at least on the compatible board list, they usually want you to match up a certain amount of numbers on the white sticker to insure compatibility.
                                      • 12274
                                      • U.S.
                                      #38
                                      Or board board or board panel incompatible.
                                        • 12274
                                        • U.S.
                                        #39
                                        Had similar problem with sony, turned out to be a simple firmware re-apply did the trick.
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
