Samsung UN60EH600 UN55EH6000 Identical Problem
  • Michale32086
    • Nov 2011
    • 1453
    I just got in a couple nice Samsungs.. Same series, one's a 55" one's a 60"
    The both will give a backlight but nothing on the display panel..
    I have replaced the Main Board on the 55 but no luck. I have a new TCON board coming..
    But on the 60", there is an added twist..
    The Power PCB had 2 blown caps (marked in red) plus a couple blackend charred areas... While pulling out the old caps, I kinda cracked the pcb, but the crack doesn't appear to have gone all the way thru the board..
    I have had instances where a bad power PCB would produce the kind of symptom I am seeing, but it's somewhat unusual.. Usually when I get a back light but no display it's usually a TCON/MAIN issue..
    Any suggestions on how to confirm??
  • Michale32086
    • Nov 2011
    • 1453
    Re: Samsung UN60EH600 UN55EH6000 Identical Problem
    Another weird thing is, when the TV is turned off, but plugged in, I pull the marked connector and the backlights come on...
    That would seem to indicate some kind of short in the Power PCB???
    • freakaftr8
      • Oct 2012
      • 3743
      No that's not weird at all. These TV power supplies are designed with pull up resistors so the back lights will come on when you disconnect connector that goes from the power supply to the main board.
      I would check the usual stuff like 12v to the tcon board and removing one panel output ribbon cable at a time
      • Michale32086
        • Nov 2011
        • 1453
        OK.. I guess I just never pulled a connector off like that before..
        Yea, I tried the ribbon cable thing.. I get a universal black screen regardless of which cable is pulled. No change in either side of the screen...
        Check 12V off the fuse???
        • freakaftr8
          • Oct 2012
          • 3743
          Yes check 12v of both sides make sure it's not blown.. Like if there's 12 V coming in make sure this 12 V going out of the fuse.
          The good news is the panel sound OK so far since removing one ribbon cable still provided a black picture
          • Michale32086
            • Nov 2011
            • 1453
            With the NEG Probe on chassis GND, I get -12.65V on either side of the TCON fuse...
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              You have your multimeter probes swapped. Anyway, your readings show the Tcon fuse is good.
              A working TV? How boring!
              • Michale32086
                • Nov 2011
                • 1453
                Really???
                • vinceroger69
                  • Mar 2012
                  • 6714
                  black in middle red on right i think
                    • 12276
                    • U.S.
                    My black lead is in com.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      I'm a idjut...
                      Thanx...
                      That explains a lot of weird readings I got lately..
                      • Michale32086
                        • Nov 2011
                        • 1453
                        I used to think I was a talented amateur...
                        Now I know I am just an amateur..
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          we all make the odd mistake i blame my age lol
                          • Michale32086
                            • Nov 2011
                            • 1453
                            OK 12.66V on both sides of the TCON fuse..
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Works for me..
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Hard to tell. These are known for tcon failures with the THINE PWM IC.
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  So, it's a pretty safe bet that the TCON is bad???
                                    • 12276
                                    • U.S.
                                    I'm in the same club, my short term memory took a permanent vacation, whatever I learn today will surely be forgotten tomorrow.
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      https://www.youtube.com/watch?v=iuHrnvAKlGw
                                      Proud owner of dozens of broken TV's and many,many,many boards.
                                      Our website and passion:http://hollenhundshepherds.com/
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Ahhh Kelly Bundy Syndrome
                                        Brutal....
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
