Sony KDL-32BX310 hot LDO regulator
  • freakaftr8
    • Oct 2012
    • 3743
    This is an interesting one. I got this TV in for repair that initally turns on but has no sound. Everything else seems to work. Oddly enough if I attempt to do a factory reset in the service menu I get upon start up the usual information about English Spanish or French then the TV start flickering and the picture goes out back lights still on. If I unplug the TV and plug it back in I'm back to my HDMI source with picture no sound. Also after about 10 minutes of operation the HDMI source will start to flicker and go out. If I freeze spray this regulator I get sound and picture.
    All voltages coming off the regulator seemed to be consistit. 12 V in and a 5 V and 3 V out. So obviously it is a dual duty LDO. Part number 00ga5w. RoHM.
    I'm going to try to replace the regulator but I have a feeling that it may be a load issue. What would you think about this?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Sony KDL-32BX310 hot LDO regulator
    Replace the regulator and report back, these complex power chips are sometimes too complex for their own good.
    A working TV? How boring!
    • CapLeaker
      Leaking Member
      • 8352
      x 2
      any pics to go with it?
      • freakaftr8
        • Oct 2012
        • 3743
        Ok I'll get it on order. Thanks guys.
          Do you have the spec sheet for this 00ga5w? All I found is the single output type:https://cdn.badcaps-static.com/pdfs/...aff348f913.pdf.
          May be it is oscillating due to bad caps.
          • freakaftr8
            • Oct 2012
            • 3743
            This is what i got. Just found it.
              OK, it is just a adjustable LDO regulator IC with Enable ON/OFF pin.
              • iglitare
                by iglitare
                09-04-2025, 07:13 AM
              • DKWS89
                Sony XBR 49x900E - Sound and backlight on but no picture
                by DKWS89
                Hey Guys,
                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                12-14-2023, 04:30 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • dronerat
                Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                by dronerat
                Hi Guys,
                This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                PSU: L48S6 FHS BN44-00807D
                T-Con: BN95-01937A
                Panel: CY-GJ048HGLVLH
                MB: NA (Currently as the TV is assembled and forgot to take picture)
                As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                It was sent to an authorized service for repairs and returned with the...
                05-15-2020, 08:03 AM
              • ronni
                Sony KD-43XE8005 with sound, backlight, no picture
                by ronni
                I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                Removing the LVDS cable results in...
                12-01-2022, 08:44 AM
