Westinghouse WD55UT4490 (?)
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Got a plea from a friend saying the above set "won't turn on" -- power indicator stays red regardless of attempts to turn the set on.
    [Don't you just hate second-hand observations? Now, THIRD hand?? ]
    I didn't realize Westinghouse made TV's (rebranded, no doubt) -- I thought they made household appliances (washing machines, etc.).
    Is this really worth my time -- given that there are so many other things on my plate, currently? A quick google suggests it was probably a cheap set so maybe the smartest move is just to advise him to buy a new (better!) set...?
    [I don't want to invite it into the house and end up committing myself to its repair]
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Westinghouse WD55UT4490 (?)
    That is going against the spirit of this forum.
    • jetadm123
      • 2169
      Over the years, Westinghouse did make a number of computer monitors and TV sets. And yes, they were not of the highest quality and the boards for the same model were made by several different companies. This is a 4K model and if you look at shopjimmy's store on eBay, there's are least 7 revisions of this set! And they're selling a package of all replacement boards for each revision for about $70. Maybe, you should have your friend fix it himself?
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        That would be worse than tackling it myself!
        "Hey, can you tell me why this didn't fix the problem?"
        "What exactly did you do?"
        "All I did, was..."
        "No, that's clearly not ALL you did -- as it doesn't explain..."
        "<shrug> Well, can you look at it and see if you can figure out what's wrong?"
        (As if his efforts have magically made the problem EASIER to solve than it was before he opted to muck with it! Even easier to just "pass" on the whole thing!)
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          "All I did, was..."
          lol
          • alro7779
            Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
            by alro7779
            Hello, guys!
            I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
            Alex....
            10-03-2025, 05:49 PM
          • elmontador
            LG RL4 (i made a mess)
            by elmontador
            Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
            09-02-2025, 03:31 AM
          • handsworth
            Tv taping method made easy
            by handsworth
            Just wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
            02-11-2025, 09:07 AM
          • rumi409
            LG OLED C1 Pixel Cleaning Made Picture Worse
            by rumi409
            ​​​​​​ Hi,
            I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
            11-15-2024, 01:09 AM
          • Nicktronic
            Westinghouse W55UW4620 No Video
            by Nicktronic
            Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
            So, backlights, no video, go! 🙂...
            06-03-2024, 03:21 PM
