samsung Un50h5203afxza nh03 no backlight
  • KPC
    • Feb 2018
    no backlight at all
    flashlight shows tv image and has sound
    caps visually look good, no doming, no leaking
    i only have a multimeter, no sophisticated testing equipment.
    ideas..?
  • nomoresonys
    • 12306
    • U.S.
    Re: samsung Un50h5203afxza nh03 no backlight
    Usual request is good clear pics. of each board and one of the whole layout.
    • nomoresonys
      • 12306
      • U.S.
      https://www.youtube.com/watch?v=4v8DcqCNG4A video of power supply board testing, use CAUTION HIGH VOLTAGE CAN BE DEADLY.
      • KPC
        • Feb 2018
        i can't seem to upload the pictures, so i put all the pictures in a shared folder on google and here is the link
        https://photos.app.goo.gl/feOEqRYjkxoolE5j1
          I can see that the LED backlights power supply section got really hot there, the board turns dark brown, right by the LED connector, you need to check the Diodes in that section where it gets very hot.
          You know how to use your meter properly, right?
          You also need to provide straight shot pictures of the whole top and bottom side of that power supply board.
          What is your power supply board P/N? BN44-?????
          • KPC
            • Feb 2018
            Bn44-00772a
              BTW, try disconnecting the cable between the min board and the power supply board and then plug the power cord into the outlet to see if the backlights will come on right away and stay on as long as the power cord is plugged into the outlet.
                09-07-2024, 05:50 AM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • sansanpartida
                Samsung QE82Q70RAT no backlight
                by sansanpartida
                Hi everyone!
                Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                My issue: No backlight.
                Model: QE82Q70RAT
                Type No: QE82Q70RAT
                The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                So hopefully, I can fix this cheaper.
                05-22-2024, 06:56 AM
              • howardc64
                Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                by howardc64
                TV was fixed just after removing Samsung's rear snap cover.
                This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                Maybe PSU->backlight connector didn't have a good contact?...
                07-23-2025, 12:34 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
