TOSHIBA LCD 37ZV635DG No picture but sound and backlight
  • nex91
    • Nov 2012
    • 37
    • Austria
    Re: TOSHIBA LCD 37ZV635DG No picture but sound and backlight
    Is the panel repairable or need to be changed?
      • 12331
      • U.S.
      Can you grab a service manual? might not be saveable, I don't think I would run it in that state. Will probably just mess up your new tcon if it hasnt already.
        • 12331
        • U.S.
        Wonder whats making the panel draw too much current.
          • 12331
          • U.S.
          https://elektrotanya.com try there I'm having a problem with acrobat reader.
          • diif
            • Feb 2014
            • 6978
            • England
            It depends, you might get lucky and find a shorted ceramic capacitor on the PCB in between the tcon and panel. Or it could be a shorted chip on the flexible film between this board and the panel, in which case it's not repairable.
            • nex91
              • Nov 2012
              • 37
              • Austria
              #26
              I found the manual there, what exactly am i looking for?
                • 12331
                • U.S.
                #27
                https://www.youtube.com/watch?v=98a8iMokMcY if you can get to those boards you might be able to test the bad one and replace a component if its not the bond itself. Have to be very careful, they're connected and they have to stay connected and they're kind of delicate.
                  • 12331
                  • U.S.
                  #28
                  https://www.youtube.com/watch?v=UNf81Z-i1FE Check that video, it's both tragic and hilarious.
                    • 12331
                    • U.S.
                    #29
                    Maybe how to test those boards with your meter, might find a youtube video on it or get guidance from one of the resident pros here. I haven't had opportunity to deal with them.
                      • 12331
                      • U.S.
                      #30
                      Shouldn't be too hard to determine the bad component if you have one, compare one of the good boards readings to the possibly bad one, see how his bad board was right where the display fault is? just need to get the test procedure right and know what to set your meter at ohm diode etc.
                        • 12331
                        • U.S.
                        #31
                        https://www.youtube.com/watch?v=yTnkOfwBGGE Nice little test there.
                          • 12331
                          • U.S.
                          #32
                          http://www.androiderode.com/how-to-test-opto-coupler/
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • DKWS89
                            Sony XBR 49x900E - Sound and backlight on but no picture
                            by DKWS89
                            Hey Guys,
                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                            12-14-2023, 04:30 PM
