Disconnecting internal tv speakers (HLT5675S) safe?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I have a samsung dlp with a bad audio processor. The boot beep cracks like hell even with the internal speaker set to off
    I'm guessing they're 4 ohm, and might just be completely safe to disconnect them? Hook 4 ohm resistors in place or should it be fine without?
    Most audio amps I've dealt with are...bigger. And I know having an amp without a speaker connected can be bad, possibly even blow it
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Disconnecting internal tv speakers (HLT5675S) safe?
    Most audio amps are safe to operate in an open load. You should have no problem, no need to replace the speakers with resistors. It is RF amplifiers that do not like being unloaded.
    A working TV? How boring!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Hm and the audio out on the side has no popping. This SO sounded like a preamp issue because of how the sound would freeze, pop, unbuffer into the amp and pop again (bad memory chip?). But I also thought the Ntp-3000 chip with its stereo output to two caps I replaced also might have been the problem (I replaced the caps, not the chip)
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        This isn't the tube days of the 60's anymore. Power amps don't care if they are run open load these days.
        Follow the white rabbit.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          Great. Brought it over. Audio out started clicking after an hour (my amp showed it had audio stable on the audio out for two hours last night). 4 hours later, blinking leds say bad fan(s). Both fans seem to be working full speed to me
          Refuses to come on. I wonder if the mainboard just got worse.
          There went $40 in new caps
          • budwich
            • Jul 2015
            • 3097
            well you certainly need to ensure any / all fans are working appropriately. Most units (projectors) have "multispeed" fans that run according to demand. what light output level were you using? IF any fan is none operational, then it is somewhat unlikely that the system will turn on... but there should also be some "led blinking" for an issue.
            • R_J
              • 9535
              Even though the fans are turning you may be missing the tach pulse, check the solder connections on the plugs on the dmd board, and check the plug itself. sometimes the wires can be loose in the plug.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                The lamp turns on for a moment, then led blink 1&3,which indicates a fan issue. Keep in mind before I wotked on it, it sat in a hot, then cold garage for 6 minths
                The lamp fan does do some humming, but I never had a problem during testing. If they haven't thrown it away, I'll see about getting some fan oil into the bearings
                Worse comes to worse, I saw a video of s guy disconnect the fan error wire from the dvd connector to the main board. Risky I know, but there is a temp sensor above the lamp to prevent a meltdown
                http://www.manualsdir.com/manuals/42...675sx-xaa.html
                • R_J
                  • 9535
                  The fan's are usually not that noisy, It could be the color wheel that you here that is humming. If you have a scope you can check and see if there is a tach pulse coming from the fan.
                  I have had to resolder those plugs before, the surface mount pins can become loose from the board.
                  • soeren
                    A2442 - No sound over internal speakers and no video playback
                    by soeren
                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                    All happened after the battery ran out of power overall several days when I was on vacation.
                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                    07-26-2024, 01:24 AM
                    Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                    by momaka
                    More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                    02-15-2022, 12:43 AM
                    HP Z400 W3520 Specification for Upgrade or Repair
                    This specification for the HP Z400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z400 boardview and Z400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z400 is accurate, safe, error...
                    09-12-2024, 03:30 PM
                    HP Z400 Workstation W3550 Specification for Upgrade or Repair
                    This specification for the HP Z400 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z400 Workstation boardview and Z400 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                    HP Z600 E5504 Specification for Upgrade or Repair
                    This specification for the HP Z600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z600 boardview and Z600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z600 is accurate, safe, error...
